If you look close at the ribon cable, you see that on the end where it connects to the control button panel there is excess room for the cable width wise. Make sure it is favored toward the end closest to the POWER button. I ran into the same problem. Also make sure the cable ends have the metal portions situated correctly against the metal (not plastic) of the connectors themselves. The 4 prong connector is for the touchscreen.
Warning! Any other cables put back together wrong can DAMAGE your expensive screen. I should know... DOU! Good Luck. Hope this works.
My Cars
"If at first you don't succeed, keep on suckin' till ya do succeed" (Stooges)
