Old 02-09-2006, 12:12 PM   #1
Shamingo is on a distinguished road
Powering my new Lilliput 619gl
Shamingo is offline   Reply With Quote
Old 02-10-2006, 07:58 AM   #2
Old 02-10-2006, 08:29 AM   #3
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
It amazes me that people purchase all this hardware without so much as a clue as to how it all goes together or a plan for making it work. Impulse buys aren't a good idea in this hobby. You're likely to end up wasting money.
You have a couple options for your Lilliput. It should come with a cigarette lighter with the infamous egg-shaped voltage regulator. These are known to flake out, however. Some people have been using their 'egg' for a long time with no problems.
That POL PSU isn't a converter of any sort. It merely provides clean, consistent power. You don't have to convert DC to DC.
If you purchased the Opus POL unit, then it can be set to provide 12v for your screen, so long as it uses less than 1.25amps, as that's all the 12v power it can provide. Check the specificiations of your Lilliput.
The Carnetix POL unit only provides 5v output, so if this is the unit you have, you're SOL for powering your screen with it.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Lilliput Powering dafook LCD/Display 4 01-30-2006 08:36 AM
Lilliput not powering on, where to look? Pale Rider LCD/Display 3 10-24-2005 06:46 PM
xenarc first impressions, tried lilliput before emdzey01 LCD/Display 7 06-09-2005 07:26 PM
Lilliput Powering On/Off problem masch LCD/Display 0 05-09-2004 12:55 PM
Powering Lilliput from AC source hevnsnt LCD/Display 5 04-25-2004 06:03 PM
