Old 02-09-2006, 01:29 PM   #1
ceBlaze is on a distinguished road
Question 3 din / verticle monitor
I have been searching the web for a 3 din monitor. Does such a thing exist?
I am just starting to get into the carputer thing, but I feel confident I could move or use some other control device for my climate control (I would love the computer to eventually do it, I think I've seen some people pull that off).
So the desired effect would be a portrait-oriented monitor that looks like it had to be stuffed into my dash. I would like it to be a touch monitor, too, but that's secondary to the size. Everything I see seems to be meant to fit landscape-wise, and the sizes jump from 8" to 10.4" to 14". Am I the only one that thinks mounting a monitor vertically would be AWSOME?
-Blaze
"Live if you can, die if you must, but always fight with honor."
"There is NO way that should have worked!" -Sahara
(O:o)===W===(o:O)
=====[XLR8]=====
ceBlaze is offline   Reply With Quote
Advertisement Sponsored links
Old 02-09-2006, 01:47 PM   #2
Freelander's Avatar
Freelander is on a distinguished road
read this
http://www.mp3car.com/vbulletin/show-off-your-project/37057-alpine-mcintosh-chopped-up-liquid-cooled-dell.html
Freelander is offline   Reply With Quote
Old 02-09-2006, 03:39 PM   #3
dmcdlrn is on a distinguished road
although not completely perfect 3 din... the 8" or 8.4 I think fits almost perfectly in a 3 din opening... I am hoping to do this with my 8.4 that I'm building right now with the backlight upgrade... there is a guy that did this...
and ended up with this...
You can check him out here...
http://www.mp3car.com/vbulletin/show...hlight=eclipse
dmcdlrn is offline   Reply With Quote
Old 02-09-2006, 03:55 PM   #4
SWEET! thanks! so now comes the inevitable question, can it be done as a touch screen? If I remember correctly, the tablet PCs are specifically designed to take input only from the stylus. Are there touch adapters for any size screen including widescreen laptops like that one?
-Blaze
(O:o)===W===(o:O)
=====[XLR8]=====
Old 02-09-2006, 04:02 PM   #5
evandude's Avatar
evandude is on a distinguished road
The screen in the pictures dmcdlrn posted is a touchscreen monitor.... he says it's a Lilliput 809GL in the thread.
(if you are referring to freelander's link then disregard this)
But don't take it from me! here's a quote from a real, live newbie:
Quote: Originally Posted by Viscouse
I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
eegeek.net
evandude is offline   Reply With Quote
Old 02-09-2006, 04:09 PM   #6
second that... its a touch screen... so is my 8.4. You can do a touch screen for just about anything without any more space really... touch panels themselves are only about an 1/8" thick and are supposed to be the same size as the screen size... then you have a small controller board and ribbon cable...
Old 02-09-2006, 04:26 PM   #7
yeah, actually i was referring to freelander's link. I may end up using an 8" because I don't want to modify much more than the hard plastic din slots, certaily not as drasticly as that mini-van, but I love how the screen in that one has almost no bezel around it. I really want it to look like it's the biggest thing i could possibly cram in.
(O:o)===W===(o:O)
=====[XLR8]=====
Old 02-09-2006, 04:35 PM   #8
also, i heard once that building up a laptop isn't all that much harder than building up a desktop. anyone have any good links?
(O:o)===W===(o:O)
=====[XLR8]=====
Old 02-09-2006, 04:44 PM   #9
I run a laptop. I don't know which is easier... laptop is much more compact though..
I am revamping and using a docking station this year so I can use the laptop's internal sound card... the docking station has a pci slot plus space under it to stick my fm tuner... and usb is all I need for devices... Normally you can buy a stock dc to dc for your machine thats designed to work... also designed to create less heat and consume less power.. plus it has a battery allready built in so it will last a crank...
downside is they are more expensive and less available typically, also less versitile normally cause of no pci slots.
But, you have to read and make up your own mind... I chose laptop and I think it was the right choice for ME... good luck!
Best monitor for Double Din? sanbas LCD/Display 10 11-19-2006 05:58 PM
Does anyone ever mod. 7' monitor w manual flip to insert the Disk on 2 Din ? calico General MP3Car Discussion 1 12-31-2005 02:48 AM
Double din VGA monitor afarre LCD/Display 9 11-07-2005 11:07 AM
ForSale: InDash (DIN) 7 inch SVGA LCD Slideout Monitor guardianzx9 Classified Archive 0 01-25-2005 08:11 PM
