Old 02-12-2006, 05:12 PM   #1
noreason's Avatar
noreason is on a distinguished road
Which has less ghosting? VGA Extension or Bus Mouse Extension cable?
I suppose the title asks the question.
Which gives less ghosting, assuming both are of good quality cable, a bus mouse extension or vga extension cable?
I purchased what seemed to be a high quality vga extension cable (it said high quality, and looks high quality, and cost me a high quality amount of money) but I get some ghosting. Would it go away with a bus mouse cable?
Thanks!
noreason is offline   Reply With Quote
Old 02-12-2006, 05:34 PM   #2
cheap custom title
JC-S60's Avatar
JC-S60 is just really niceJC-S60 is just really niceJC-S60 is just really niceJC-S60 is just really niceJC-S60 is just really nice
You mean sending your VGA-signal over another type of cable?
Depends on the cable I guess.
The whole ghosting thing is also dependant on the strength of the signal from the videocard and the resolution...
JC-S60 is offline   Reply With Quote
Old 02-12-2006, 05:36 PM   #3
noreason's Avatar
the lilliput has a breakaway cable that you can apparently connect a bus mouse extension cable in between. i forgot to mention that for anyone unfamilliar with the lilliput sorry
Old 02-12-2006, 05:39 PM   #4
kraft is on a distinguished road
low power or bad ground can also change things...
kraft is offline   Reply With Quote
Old 02-12-2006, 07:42 PM   #5
Silentbob343 is on a distinguished road
I would hazard a guess at the VGAcausing less problems as there isn't any other wire running with it, i.e. USB.
Silentbob343 is offline   Reply With Quote
Old 02-12-2006, 08:24 PM   #6
noreason's Avatar
cool i havent tried it in car yet (the vga cable) but im about to in a few minutes! hopefully it ghosts less in there
Old 02-15-2006, 04:08 PM   #7
LiquidKernel's Avatar
LiquidKernel is on a distinguished road
How long of a cable did you buy?
95 Volvo 850 T5 • Konis • ECU @ 17psi • Orange Ambient-Light + LED Dash Lights • DigiMotive Dimmer • Custom LED Brake Lights • TSX HID Projector Retrofit • Hella Raintronic
Carpc: [▓▓▓▓▓▓▓] 99% Cleanup.
LiquidKernel is offline   Reply With Quote
Old 02-15-2006, 04:23 PM   #8
noreason's Avatar
10' which is about perfect in length.
I also want to say that the ghosting isnt horrible and doesnt bother me much, but it's there.
1997 Saturn SL2 Car PC Status [..........] 0% Complete (Removed)
1999 Honda Accord Car PC Status [::::::::..] 80% Complete (Setting up software before final install)
Old 02-15-2006, 04:35 PM   #9
ElKeeed is on a distinguished road
You shouldnt get ghosting on a lilliput over a decent 10' cable unless you try to use a res higher than 1024x768.
ElKeeed is offline   Reply With Quote
Old 12-21-2006, 10:18 PM   #10
toxiclows's Avatar
toxiclows is an unknown quantity at this point
It happens though. I am getting ghosting since adding a new no name 6 footer to my lillis cable. . . I am searching for a solution... surely ppl have found a way to deal with this. . . Most ppl put there puter in the rear and the screen in the front. . . and have to extend. . . .. Suggestions are welcomed. .
toxiclows is offline   Reply With Quote
VGA cable problem on DWW-7VGA, need pictures OzPaddy LCD/Display 4 03-16-2004 02:34 PM
USB gps mouse , max lenght cable BOND007BE General Hardware Discussion 3 12-17-2003 07:54 PM
Vga to Svideo cable? si2001 LCD/Display 3 11-01-2003 02:33 PM
LCD extension cable ThinkPad 560 hakan LCD/Display 1 03-22-2002 08:36 AM
Can't get VGA extension cable to work... SuperMatty LCD/Display 2 01-14-2002 05:07 PM
