Old 02-13-2006, 06:50 PM   #1
Lilliput 70NP flickers when I set resolution to 800x480. Please help!
I just got a used Lilliput off of MP3car and I got it all hooked up and turned it on and it worked perfectly. I then tried to set the resolution to 800x480 and when I do that it looks fine on my laptop but when I look at the Lilliput screen it is just sitting there and it is flickering. It will show the screen and then it will go away and when you see the screen it is offset to the right a little with a couple of lines towards the lower left hand corner. It will just sit there and flicker like this on and on until I change the resolution to anything different. Every other resolution it seems to work fine with. If any body has any ideas please help me out. Thanks!
-haryy
zac_haryy is offline   Reply With Quote
Old 02-13-2006, 07:30 PM   #2
Neither darque nor pervert
DarquePervert's Avatar
Try adjusting the refresh rate.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 02-13-2006, 09:21 PM   #3
I looked in every menu on the screen and I couldn't find a refresh rate anywhere. It is something to do with the settings on the monitor and not the computer right?
-haryy
Old 02-13-2006, 09:29 PM   #4
Well I found the refrech rates on my laptop (figures) and I messed with them and set all kinds of different settings and it would change my laptop LCD monitor but the lilliput still would sit there and flash on and off. Its looks really wierd. Is there a certain Hz that you would recomend trying?
-haryy
Old 02-13-2006, 09:32 PM   #5
Kalt's Avatar
At 800x480 mine works best at 72 hertz
Kalt is online now   Reply With Quote
Old 02-13-2006, 09:51 PM   #6
I must be doing something wrong.....I have powerstrip installed of course and when I go into the display properties on Powerstrip I select 800x480 and then right under that there is a section that says refresh rate. What is the easiest way to change the refresh rate? When I go into the advanced timing options there is a vertical refresh rate and a horizontal refresh rate. Is this what I want to change? I'm a newb when it comes to refresh rates and such. Let me know. Thanks!
-haryy
FAQ: VGA vs. Composite (Video) Screens cproaudio The FAQ Emporium 2 12-28-2007 12:45 PM
800x480 resolution for Lilliput fireball106 LCD/Display 7 02-24-2006 01:59 PM
does anyone have a set of lilliput controller boards spare???? sham LCD/Display 5 02-18-2004 02:54 PM
Sis650 and lilliput 7": how to set 16/9 pianetadigitale General Hardware Discussion 0 02-15-2004 06:03 PM
How to set 800x480 under Windows XP chrisgearing LCD/Display 25 07-29-2003 08:02 PM
