Old 02-19-2006, 12:22 PM   #1
jurassic262's Avatar
worked in house
alright i got my install all set worked fine in the house then set the damn thing up in the car, everthing worked fine but my lilliput. i'll i get from the lcd is a jurassic park logo nothing else. just wondering if this has happend to anyone else. did a google search all last night and i could get was that the J-park logo is normal and set from the company so just need to know how to get my picture back.
jurassic262 is offline   Reply With Quote
Old 02-19-2006, 12:31 PM   #2
Self proclaimed spoon feeder
TruckinMP3's Avatar
What changed ?
I would think the Power Supply and you moved the system.
Start by checking all the connections that you removed and re-connected.
Also make sure the power supply is working. If you are using an inverter or a DC to DC solution, replace it with a desktop supply you know works and use an extension cord to house power.
This will tell you if it is a power issue or a connecter issue (this type of issue is common) If those changes do not get results you will need to post detailed specs of your set up. (hardware and software)
Good luck
TruckinMP3
Self Proclaimed Spoon feeder!
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
Old 02-19-2006, 01:00 PM   #3
first this is what i have a epia V boad, 60gb hd, opus 150 psu and the lcd is a lilliput 619gl. had everythg powered by a desktop psu like i said before everything worked fine . so yes the only thig that changed was the PSU. i have checked all the connections and removed and re-connectd and still get the damn J-park logo. ok i hookd up a dvd player and got the same thing. so nomatter wat i hook u to it now i get the J-park screen ad nothing else
Old 02-19-2006, 02:25 PM   #4
TruckinMP3's Avatar
Did you try a desktop PS on an extension cord?
Can you try a different display?
TruckinMP3
Read the FAQ!
Old 02-19-2006, 07:09 PM   #5
i took it back to the house and hooked it back up to a desktop PS and still get the samething, and the pc works if i hook it up a differnent display
Old 02-19-2006, 07:58 PM   #6
TruckinMP3's Avatar
What does that tell you?
PC works with a different display.... maybe the LCD is bad... sorry dude.
TruckinMP3
Read the FAQ!
House power for 2.66 GHz Celeron PatO Power Supplies 0 04-30-2005 11:51 PM
In car and in house?... daem0n Power Supplies 7 04-23-2005 05:24 PM
House eats wireless signal d_sellers1 Wireless Communications 20 08-17-2004 08:29 PM
Quality of power in house Dartman111 Off Topic 3 06-13-2004 11:27 PM
Bought a house (That didn't have cable) PatO Off Topic 8 05-08-2002 08:19 PM
