The MP3car.com Store
Thread Tools Search this Thread Display Modes
Old 03-04-2006, 11:43 AM   #1
Vehicle: 2008 Mitsubishi Colt Insport 1.3
My Photos: (0)
Is my Xenarc 700TSV busted ??
Hello.
I tried installing an Xenarc 700TSV in an friends car, it acted up with his IBM laptop with Intel graphics, so i took my screen and tried with that, same problems, it couldn't detect the resolutions correct...
We have changed the computer now, and my screen is still in his car, i didn't want to change it again as it seems like both screens were working fine.
I am in the process of slowly mounting an PC in my car now, but i have serious problems with the screen...
At 800x600 @60 Hz the screen acts up like this:
And running at 1024x768 @60 Hz it does this:
Have tried with three different laptops, and two desktop computers, same result....
Any idea of what's wrong ? Could the monitor cable be busted ??
Regards, Per, Denmark.
zapro is offline   Reply With Quote
Sponsored Links
Old 03-04-2006, 09:04 PM   #2
muldrick's CarPC Specs
muldrick's Avatar
Vehicle: 2004 Hyundai Accent
My Photos: (2)
From the pics, it looks like it's taken apart...what did you do? Was it working before?
Search for "ribbon", seems like you may have messed up the ribbon cable.
Let us know.
Now faith is being sure of what we hope for and certain of what we do not see.
muldrick is offline   Reply With Quote
Old 03-04-2006, 09:07 PM   #3
Raw Wave
kickercivic1's Avatar
Vehicle: 07 Jetta
My Photos: (0)
the screen is not getting enough power.
07 Jetta
Carputer:
Voompc-2, Intel 1.33, 1GBram, 60gb HD, Dynamix 8"
Audio:
front Qsd 216
Rear QSD 213
Rockford (2) p2 10" subs
JL 500/1
JL 300/4
Audigy 2 nx
kickercivic1 is offline   Reply With Quote
Old 03-04-2006, 09:26 PM   #4
My Photos: (0)
No Powaaaaaaaaaaaaaaaaa
1BadRbt is offline   Reply With Quote
Old 03-05-2006, 10:47 AM   #5
My Photos: (0)
Well..
Wel thanks, i will look into it today, to find the problem.
I am 100 percent sure it's not the ribbon since OSD menus and start screens just fine, and if the ribbon was faulty it wouldn't look right either... It just seems like the screen cannot sync to the signal i give it...
I am using an 12V / 5 Amps power supply for powering it at this time, i will try with an Laboratory Power supply now...
Will return with my findings...
Regards, Per.
Old 03-05-2006, 11:08 AM   #6
My Photos: (0)
No good...
Hello.
I have tried the suggested things and to no help.
The ribbon is fine, Start logo "Portable Display" and OSD menus work just fine, and the whole area on the display works fine.
I have powered the display by an big Laboratory supply now, and having the same problems, also tried to up the voltage to 15 Volts, no help.
When i am changing resolutions the image is correct to start with, but then it fall over to the right and it just ends with a bunch of stripes..
I have also tried with an new signal (VGA) cable, no change...
Is there anybody that have seen this before ??
And yes, i have taken it out of it's case...
Regards, Per.
Old 03-05-2006, 09:19 PM   #7
wi77iam's Avatar
Vehicle: 2004 Subaru WRX STi
My Photos: (0)
You need to go into the OSD menu and select Auto Sync (or something like that). My Xenarc will do this occasionally - I run it at 800x600@60Hz and it looks just like your first pic. The only way to get it right is to re-sync it.
wi77iam is offline   Reply With Quote
Old 03-05-2006, 11:16 PM   #8
My Photos: (0)
Well
I HAVE done just that but no help, it detects the resolution again, always thinking it's 1280 horizontal, and then what it is vertical - it detects correct.
e.g. inputting 800x600@60 Hz will look like 1280x600@60 Hz for the monitor (or somethin like that), and inputting 1024x768@60 Hz will be detected as 1280x768@60 Hz....
Changing the resolution on the computer also tend it to auto-sync again, showing the new resolution...
I think i'll have to get me a new monitor, this won't work at all.... Damn crappy monitor.
Regards, Per.
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
FS: Xenarc 700TSV $250obo tejesh83 Classified Archive 4 02-12-2006 08:24 PM
Xenarc 700TSV and Gain 700TSV the same? thrmaln LCD/Display 9 02-10-2006 08:22 PM
Xenarc 700TSV Resolution blackflux LCD/Display 2 05-18-2005 01:51 PM
Does Xenarc 700TSV & Xenarc MP-SC1 allow 800 x 480? xga LCD/Display 7 11-09-2004 02:33 AM
FS: Xenarc 700TSV touch UXGA capable cproaudio Classified Archive 16 01-20-2003 06:38 AM
Sponsored Links
Ad Management by RedTyger
