Old 03-05-2006, 07:21 AM   #1
Lilliput Power
I have lost my power support for a car adaptor for my Lilliput 619, is there an orginal or compatible solution?
World705 is offline   Reply With Quote
Old 03-05-2006, 07:42 AM   #2
MySQL Error
Scouse Monkey's Avatar
power support????
power supply?
you are best powering the screen off your PC power supply anyway as those lighter adapters are generally crap. Alternatively, look for a regulated dc-dc psu with 12V out. and don't get the polarity wrong or boom!
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
Scouse Monkey is offline   Reply With Quote
Old 03-06-2006, 04:57 AM   #3
yeh meant supply..
what one will i need ?
Old 03-06-2006, 04:58 AM   #4
MySQL Error
well something that gives 12V out, regulated and at leat 1A.
Old 03-06-2006, 06:51 AM   #5
http://www.carcomputer.co.uk/touchsc...php?product=56
would that be compatible ?
Old 03-06-2006, 07:14 AM   #6
MySQL Error
good greif mate, are you really building a carPC?
I have never seen that company before, or the adapter but by the looks of it - from the sticker on the front it is likely (12V out). If it is in the touch screen section than it is more than likely. As they seem to only sell lilliput screens then even more likely.
did you email them to check?
There is no power rating but i imagine it is capable of a measly 10W as it is in the screen section and the only other issue would be the plug size and it's polarity.
Why dont you just hook your screen up to your computer PSU? I dont like those little power regs.
Old 03-06-2006, 07:22 AM   #7
Confusion Master
Enforcer's Avatar
Quote: Originally Posted by World705
That's the dreaded Lilliput Egg
Enforcer is offline   Reply With Quote
Old 03-06-2006, 07:26 AM   #8
MySQL Error
in that case dont bother. run it off yur psu. there is a sticky about it in the LCD section.
EDIT: didnt they make it better? or is it still cr@p?
EDIT2: cos they kept frying!
Old 03-06-2006, 07:30 AM   #9
Confusion Master
Enforcer's Avatar
I used to use them but since my second went tits up I have been using something else, will see if I can find a link
Old 03-06-2006, 09:06 AM   #10
already built.. and customised..
only lost the power cable to monitor.. i've done all install including flushing in to console etc.
Old 03-06-2006, 09:40 AM   #11
if i connect directly to the psu yellow/black cables do i need a regulator ?
http://www.mp3car.com/store/product_...products_id=62
Old 03-06-2006, 11:29 AM   #12
MySQL Error
your psu is a regulator. so no.
make sure you use the black next to the yellow.
as for a cable you can go to maplins and buy some wire and a jack plug for less than the shipping from the USA. Or just cut the cable off your mains adapter
lilliput power problem billco105 LCD/Display 10 10-30-2006 03:09 PM
Lilliput turns on without any power.....WTF! Zebelkhan LCD/Display 23 08-16-2005 09:24 PM
Anything wrong with just leavin the lilliput on power saver? Sonicxtacy02 LCD/Display 4 04-11-2005 03:33 PM
Lilliput Power Polarity? aleromaster LCD/Display 8 09-10-2004 02:22 PM
Possible to power lilliput this way? ScorpionV LCD/Display 9 07-19-2004 07:39 AM
