Old 03-05-2006, 06:07 PM   #1
MySQL Error
Sonicxtacy02's Avatar
Question about lilliput. Can i extend these wires?
i need to extend these wires cause i need to lay the controller flat (thanks to the stupid 8" bottom connector. Any problems with me just cutting them and adding a lil 12ga. wire? I'd only need about 6" or so. I just dont want to cut the wires and find out there like rca or some funky wire.
03 Acura RSX Coupe
a K.I.S.S Flash, VB, and Autoit Programmer
Developer of: RRFusion, MovieTimes, (new)RRMail, & RR Plugin Manager
Coming Soon:RRChrome, & CentraFusion
Is Your RR Plugin Managed?
Old 03-05-2006, 06:12 PM   #2
Banned
Motorcity's Avatar
yes, there is a big problem! those are AC Voltage wires, not standard wire.
you need to use the correct wire type, and splices need to be soldered and covered with UL approved heat shrink, or electrical tape.
If you have an old lcd panel laying around, scavange the wire from the backlight.
otherwise, I highly recommend you purchase the correct supplies needed to extend those wires.
Motorcity is offline   Reply With Quote
Old 03-05-2006, 06:26 PM   #3
MySQL Error
Ok, what is the correct wire type exactly?
03 Acura RSX Coupe
Old 03-05-2006, 06:39 PM   #4
Banned
xdjxklusivex's Avatar
wow if u mess up ur gonna get fryed lol
xdjxklusivex is offline   Reply With Quote
Old 03-05-2006, 06:52 PM   #5
MySQL Error
lol i assume if i unplug the thing i'll survive.. All it is is 12 volts right
03 Acura RSX Coupe
Old 03-05-2006, 07:08 PM   #6
Banned
Motorcity's Avatar
wrong. try 800+ volts...AC
Old 03-05-2006, 07:11 PM   #7
Banned
Motorcity's Avatar
http://www.mouser.com/index.cfm?hand...denumber=56005
available in white and pink. you can use either or. no need to buy both colors, they are the same AWG.
use heatshrink tubing, to cover the solder splices.
this wire is high voltage rated, and is silicone.
Old 03-05-2006, 07:38 PM   #8
MySQL Error
Thanks for your help. So i purchase this wire. Cut the connectors at the connector solder in these and use heatshrink tubing and we're fine and good? I assume once i've unplugged the lilli from the ac adapter there's no risk of shock right?
03 Acura RSX Coupe
Old 03-05-2006, 10:10 PM   #9
listen though 800 v ac ain't no thang, depends all on current. after seeing a guy last week fly 20 feet from touching something with 8v and 200a (no he magically didnt die just blew a hole out the bottom of his boot, i would say no worries.
all you have to do is get the correct wire it looks like 16 gauge wire to me. wire type only matters when running it long distance due to internal resistance of the wires. Hopefully you know how to solder however if you don't you can call me and i can step you threw setting the temp, using flux, all the shenanigans.
you should be fine if you make the correct union on the wires and don't get crazy trying to run to high of a current. the best thing i would do is get an amprobe and power it up place it over the wire and take the reading from there, but if money is an issue to buy one then try home depot for a multimeter (15 bucks) and i can step you through testing safely.
1BadRbt is offline   Reply With Quote
Old 03-06-2006, 12:21 AM   #10
Banned
Motorcity's Avatar
all I can say is, you don't know what the hell you are talking about........
Old 03-06-2006, 12:27 AM   #11
Banned
Motorcity's Avatar
correct. make sure the lilli is unplugged, then disconnect the backlight connector like you have shown. Cut the wires and solder in the added length you need. Allow at least 1" from the connector if possible so you have enough room to solder.
Be sure to use the wire I referenced, and Not regular wire.
A regular piece of wire is only rated for 125 volts. True, the amp draw on the backlights is not that high, but the voltage is over 500 v AC. This will fry a regular pc. of wire in no time flat. You need the high voltage wire, with silicone sheathing to guarantee you won't have issues.
side note: the AWG size of your wire is 24awg. The reason it looks larger in your pictures is the fact that the silicone cover is thicker than regular pvc that regular wires have.
good luck, and please spend the few $$ on the right wire.
Old 03-06-2006, 07:33 AM   #12
MySQL Error
I'm gonna buy from the site you suggested. Thanks!
03 Acura RSX Coupe
Old 03-06-2006, 10:41 AM   #13
MySQL Error
MatrixPC's Avatar
I am not sure what wire works but I use regular wire and it has been fine for the pass 2 years.
BTW, it's not a lilliput but a modded PSone screen instead.
And you can only extend for a very SHORT distance.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 03-06-2006, 11:16 AM   #14
MySQL Error
i wont even need it as long as yours there. Just enough to lay the damn board flat.
03 Acura RSX Coupe
Old 03-06-2006, 03:05 PM   #15
eCar™'s Avatar
You really are playing with fire there.
As Motorcity said, you have several hundred volts there. The higher the voltage, the easier it is for the current to jump a gap. You really should be using a wire with a thicker insulator.
1BadRbt, what were the conditions when your friend got zapped by 8V? As most of us know, even the 12V of a car battery, which is capable of delivering hundreds of amps, doesn't have the potential (voltage) to overcome the high resistance of the human body (in normal conditions) enough to give you a tingle.
eCar™ is offline   Reply With Quote
lilliput warranty question SuperFastCVT LCD/Display 3 01-29-2006 06:22 PM
Lilliput Problem, and Replacement Xenarc Question Mrbmw99 LCD/Display 2 07-04-2005 07:08 PM
8" Lilliput question, extracting sound and screen rolls clean customs LCD/Display 5 06-30-2005 11:10 PM
New Lilliput Touch Panel install have question PHiLiSO LCD/Display 3 08-04-2004 03:18 AM
question about relays and high gauge wires Heedunk General MP3Car Discussion 12 05-10-2001 12:13 PM
