Old 03-07-2006, 08:46 AM   #1
Innovatek IN-7031 Wiring
Hi,
I have recently acquired an Innovatek IN-7031 in-dash TFT but have no information on the wiring harness. Any information on which colour wires do what (particularly the blue one) would be gratefully received.
Cheers.
Harry_Morgen is offline   Reply With Quote
Old 03-07-2006, 11:34 AM   #2
Banned
Motorcity's Avatar
Quote: Originally Posted by Harry_Morgen
Hi,
Cheers.
pictures please.
can't find the unit you reference. Is it a multifunction hu? (cd, dvd, or stereo?)
if the unit has a stereo, or cd player, etc. the blue wire is most likely the soft power on for an amp.
Motorcity is offline   Reply With Quote
Old 03-07-2006, 05:04 PM   #3
It is just a monitor, no tuner or anything else. I've managed to figure out the obvious ones, red, yellow, black and the 2 video inputs but there is this extra blue wire which must be there for a reason, i just don't know what!
Old 03-08-2006, 12:39 AM   #4
Banned
Motorcity's Avatar
ok, so it most likely is not a remote power on for an amp. It is then probably a ground wire ment to be hooked up to the transmission range indicator switch (tells the car's computer what gear the trans is in) or to the neutral safty switch. this is a safty feature to prevent the lcd from working when the vehicle is in drive, to prevent the driver from viewing the lcd. This is just a guess, since I don't actually have the monitor in hand, nor can I locate the diagram. I am asuming of course that you did and right??
Old 03-08-2006, 02:10 AM   #5
Yep, i did every search you can think of. The only reference to this unit is in this forum, a thread posted about a year ago. I'll stick a meter on it and see whether there is any voltage, if there is i'll ground it down through a resistor see what happens. If there isn't i'll pull it high through a resistor, again see what happens.
Thanks for your help.
Innovatek wiring....lights never go out.... myykk LCD/Display 7 03-08-2006 01:12 AM
Need Help - BMW's Signal Differential Speaker Wiring, Amps and SVEN4 lloydy Car Audio 8 02-14-2006 07:43 PM
if you designed a vehicle's interior and wiring, how would you do it? stapan General MP3Car Discussion 7 12-26-2005 02:56 PM
Wiring Xenarc to wiring harness? deftones8769 Power Supplies 5 04-10-2005 10:07 AM
Specific wiring schematic 4 Optrex DMC40457? sooty LCD/Display 9 07-17-2001 03:11 AM
