I was trying to extend the IR sensor on my Lilliput 629GL-70NP and I think I may have fried something. Here's what I did:
I used a soldering iron to heat and remove the IR sensor from the button board. Here's the piece that I removed (sorry for the fuzzy cam-phone image).
I removed it by desoldering the three little prongs that are soldered to the button board.
Once the piece was removed, I soldered three 18 gauge wires directly to the board where the three prongs used to attach. Then, I soldered these wires to the appropriate prongs on the IR sensor, effectively extending the sensor about 12 inches.
After the first attempt, the remote did not work but all the buttons on the front of the Lilliput still worked. So, I took it apart, resoldered everything carefully and hooked it all back up. After the second soldering job, the remote still did not work and only the PC/AV and Power buttons on the front of the Lilliput worked. The Menu, <, >, Vol+, and Vol- no longer work.
So, anybody very familiar with the Lilliput button board...did I fry it? Any way I can test it?
