The MP3car.com Store
Thread Tools Display Modes
Old 03-10-2006, 07:34 AM   #1
Snootch's Avatar
Vehicle: 2000 Pontiac Trans Am
My Photos: (0)
Help! Lilliput changed input, I am missing buttons
When I installed my 8" Lilliput, I molded it into my dash, and then I set it up for VGA input, and programmed it using the remote to auto-power on. Since it was always powering on, and always powering up to the VGA input, I un-plugged the circuit board that contains the buttons and IR sensor. I recently have been having a power problem where my powersupply won't supply enough power at startup to run all of my devices. So I have been popping the fuse out of the Lilliput "egg" (or box in the case of the 8") until the PC boots up, then putting the fuse back in, allowing the screen and all the devices (and the screen) to be running while the computer is on. This morning, I did that, but when the screen came up (usually with "VGA MODE") with "VIDEO-1", then s small green and white box saying "C-VIDEO no input". I believe the screen switched from auto-sensing the VGA input to auto-sensing the composite input. Since I no longer have the buttons or IR eye attached to the screen (it got thrown out) is there any way to switch it back to VGA? Does anyone have a broken 8" lilliput I can buy the button circuit board from? Please help! Thanks!
WORKLOG
VIA SN18000/1Gb GEIL PC3200/100Gb 2.5"HD/8" Phylon TS/BU-353 GPS/Powermate/M2-ATX PS
Webpage
Snootch is offline   Reply With Quote
Sponsored Links
Old 03-10-2006, 07:49 AM   #2
Confusion Master
Enforcer's CarPC Specs
Enforcer's Avatar
Vehicle: 1997 BMW E36 328I
My Photos: (1)
You could just short out the pin for switching with the gnd or +V, but yu would need to know which ones they are.
Enforcer is online now   Reply With Quote
Old 03-10-2006, 03:06 PM   #3
Snootch's Avatar
My Photos: (0)
Anyone? This really sucks to have no tunes.
WORKLOG
Webpage
Old 03-11-2006, 07:32 AM   #4
Snootch's Avatar
My Photos: (0)
Thankfully Armen at DigitalWW hooked me up. apparently the control signals sent by the button boards between the 7" and the 8" are alike. So i'm getting a 7" button board from him so I can change the input. Since i am using the screen without it's enclosure (molded in) I can just tape it to the driver board in case this happens again.
WORKLOG
Webpage
Old 03-24-2006, 07:09 AM   #5
Snootch's Avatar
My Photos: (0)
okay, I recieved a 7" Liliput button board from Armen @ DigitalWW, and I tried it this morning. I still cannot get into the menu with it. The monitor powers on, I see a green "VIDEO 1" that pops up at the top left of the display, then a green and white box in the middle of the screen saying "C-video, no input" i've pressed all the buttons on the button board, and nothing happens. The only indication I have that it is hooked up correctly, is the center two buttons when pressed, cause a amber LED an the end of the board to illuminate. No other button presses do anything. I made sure the ribbon cable was well seated at both ends, and no change. Does anyone have any idea of what I can do before i am forced to buy a new panel? Thanks.
WORKLOG
Webpage
Old 03-25-2006, 06:12 AM   #6
Snootch's Avatar
My Photos: (0)
Ttt
WORKLOG
Webpage
Old 03-28-2006, 05:25 AM   #7
Snootch's Avatar
My Photos: (0)
TTT, anyone?
WORKLOG
Webpage
Old 03-28-2006, 06:13 AM   #8
MySQL Error
jcdillin's CarPC Specs
jcdillin's Avatar
Vehicle: 2002 Dodge Ram 1500 Quad Cab
My Photos: (3)
doesnt sound like it's the right board, because you should get a red light on the end of that little pcb when the screen is in standby, then it should turn green when powered on. You should be able to turn it off and on, it's not doing that then that PCB is not compatiable.
But make sure you have the ribbon seated all the way towards the middle of the button pcb. it shouldnt be in the middle of the connector.
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 03-28-2006, 07:22 PM   #9
Snootch's Avatar
My Photos: (0)
Could you be a little more specific? I don't understand what you mean by "it shouldnt be in the middle of the connector"
WORKLOG
Webpage
Old 03-28-2006, 08:03 PM   #10
MySQL Error
jcdillin's Avatar
My Photos: (3)
The connector on the button PCB, most of them are bigger than the actual ribbon cable.
See in the attached picture how there is a gap between the ribbon and the left side of the connector?
肚子笑痛了
S60 Install
Sponsored Links
Old 04-02-2006, 10:42 AM   #11
My Photos: (0)
you ever get it working? I had the same thing happen to me last month and I ordered the buttons and ribbon from Armen and He just up and disappeared on me.............. going on 3 weeks.
Anyone else know where I can get some buttons and ribbon for 7' Lilliput lcd?
chatsukz is offline   Reply With Quote
Old 04-15-2006, 02:00 PM   #12
Snootch's Avatar
My Photos: (0)
No, I never did get this to work... I ended up buying a new LCD. I do have the 7" button board with ribbon that he sent me. Where are you located? If it doesn't cost too much to ship, I could send it to you & maybe it could fix your problem.
WORKLOG
Webpage
Old 07-06-2007, 11:23 AM   #13
Vehicle: 1995 Acura Integra GS-R
My Photos: (0)
I've had the exact same thing happen to me. It's not the button board. The monitor just won't go into VGA mode... I guess I'll have to buy a new monitor if you never figured it out Nobody seems to have any ideas at all on this problem. I know it wasn't my buttons that kept it from switching, I've reseated the ribbon cable 100 times and it is the original buttons for the monitor. It's something wrong in the monitor, but I have no clue what.
Thrasher is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
need help with lilliput RCA video input CDesigns LCD/Display 9 04-04-2007 06:33 PM
Lilliput in Sun Visor Project antimatter LCD/Display 67 06-14-2005 01:06 AM
xenarc first impressions, tried lilliput before emdzey01 LCD/Display 7 06-09-2005 06:26 PM
Lilliput buttons zmann LCD/Display 3 09-01-2004 11:39 PM
Lilliput composite input flashing? Misanthro LCD/Display 1 12-09-2003 03:58 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
