Old 03-11-2006, 11:25 PM   #1
Screen recommendation
Hi guys,
I'm planning on taking the jump and building a car PC and I'm trying to decide on which touchscreen to go with.
I understand a VGA screen is the way to go, it will likely be running Frodo Player so I THINK the resolution I want is 800x480?
The screen will be integrated into the current location of the existing double DIN head unit here:
so it doesn't need to be motorized, and I plan to fabricate it such that it looks like a factory install.
About the only other requirement is that I will want a reversing camera so extra RCA inputs would be nice.
So, what do people recommend? I was planning on a Lilliput but there seem to be reliability issues, is that a fair comment? What other alternatives are there that are best?
Many thanks,
Ben
Blipman is offline   Reply With Quote
Old 03-11-2006, 11:44 PM   #2
pancakeboy's Avatar
Post
Please someone reply to this. I was going to post the same question but i have not started fabricating yet. I have the 1991 ls400/celsior. On this dash there is no trim piece to fabricate with. I was thinking to take a piece of abs plastic and cut out a place for my monitor on it. Just fyi, I have the sp7 wide screen (Very Nice )i bought from the mp3car strore and it wont fit just taking the radio out, about 1/4 to 1/2 inch to tall. I was going to take out the ashtray so i have enough room for my aftermarket headunit and my screen. My trac doesnt work anyway. I could mold new buttons for my seat heaters.
pancakeboy is offline   Reply With Quote
Old 03-11-2006, 11:58 PM   #3
My Village Called
0l33l's Avatar
Move AC unit down. Remove radio. Now you have space for a 7" LCD
PowerVoice v1 | NaviVoice Source
GammaControl v2.4
SKINbedder v3
1995 Lexus SC300 <-- Weekend Car
1997 Mazda Miata <-- Daily Driver
0l33l is offline   Reply With Quote
Old 03-12-2006, 12:50 AM   #4
pancakeboy's Avatar
Post
Unfortunatly, you cant move a/c down. If you look closely, the dash gets smaller like a V. you can only move it down like a inch and a half at most. Even if you could it wouldn't give you any more room than before with radio out. What about Fab process. Bondo, Epoxy, Abs poxy weld, Fiberglass? Suggestions?
Old 03-12-2006, 12:55 AM   #5
My Village Called
0l33l's Avatar
Ok... so then put the screen in the location of the radio. Looks like it would fit. Maybe w/o the housing.
GammaControl v2.4
SKINbedder v3
Old 03-12-2006, 01:22 AM   #6
pancakeboy's Avatar
Yeah It'll fit without the housing, just relocate the buttons. That may work for Blipman, if he is going headunit-less, but i wanted to fit my headunit in the dash too. It has a nice on-screen display, and i dont want to waste the money i spent just to fit the screen in there. Just fyi, i am fitting my screen, headunit, and a usb hub in there.
Old 03-12-2006, 05:17 AM   #7
Pankcake boy! You're my new best friend! Keep me posted on how your install goes and I'll do the same.
My car is actually still in Japan and will be shipped to me (in Australia) soon so I haven't started measuring things yet, I was planning on moving the climate control down but could see it may be a problem, I guess if you've measured it there just isn't enough room
I was planning on putting the screen in the existing double DIN location, what do you need a head unit for if you've got a PC?
In terms of getting the screen in there, I was planning on making a flat sheet to cover the hole out of plastic or wood, cut out a hole, put the case in te hole and secure, then fill in the gaps and it will look flush... should actually be a lot easier than some cars.
As to my original post.... anyone?
Ben
Old 03-12-2006, 04:56 PM   #8
pancakeboy's Avatar
Blipman...I kept my headunit just so on short trips i can choose not to boot up the computer and rely on it just to listen to music. Also if anyone else drives the car(not likely ), and dont know what they're doing, they can listen to the cd player. I was thinking of filling the space with abs plastic and cutting a hole for screen, epoxy, then bondo flush, but i will be removing the ashtray...
Old 03-12-2006, 05:02 PM   #9
Trancerush's Avatar
Hey. I might have the answer to Your questions.
I have the same car (LS400 here in the states) I will send You some pics of my install. I removed the radio and ashtray and I got 7" XENARC right below it sloat loaded DVD and below DVD remapped push buttons from XENARC.
If I was going to do all this again, I'd definitely go with 8" since there is enough space. If You got the funds for 8" dont settle for less.
I will get home, hten I can post some pics of what I have.
GOOD LUCK - Sebastian
Trancerush is offline   Reply With Quote
Old 03-12-2006, 05:02 PM   #10
MySQL Error
Scouse Monkey's Avatar
what the hell is that on the passenger side of the dash?
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
Scouse Monkey is offline   Reply With Quote
Old 03-12-2006, 05:11 PM   #11
n00b 4 life
mp3oplecarrier's Avatar
Thats what I was thinking! It looks like my nans old sideboard from the '60's!
New Car
New Car computer will follow........
(Gazes at pile of components)
mp3oplecarrier is offline   Reply With Quote
Old 03-12-2006, 05:13 PM   #12
MySQL Error
looks like some kind of drinks holder with coasters
Old 03-12-2006, 05:16 PM   #13
n00b 4 life
This is where we are going wrong installing pc's tv's etc...
A bar, that's what we should be fitting!
New Car
Old 03-12-2006, 06:01 PM   #14
MySQL Error
well i could hang a fruit basket from my rear view mirror and have a blender and ice box for smoothies! gonna need a bigger inverter though as my blender is 500W
Old 03-12-2006, 08:51 PM   #15
Trancerush's Avatar
Blender...
Oh ****! Ha, ha, ha ;0
FAQ: Everything you need to know about your LinITX/MM400/TView Scouse Monkey LCD/Display 27 12-25-2007 11:34 PM
Free screen protector for Lilliput 7'' (please add other models too) sstylos LCD/Display 36 11-09-2005 01:26 AM
Has anybody ever got lil/Xen screen to clock onto native res? ChrisC LCD/Display 5 04-30-2004 12:25 PM
BMW pre-installed system - TFT ? tsingsu LCD/Display 11 08-05-2002 03:16 AM
NEC Versa M/75 Laptop TFT screen w/touch Macgyver777 LCD/Display 23 03-24-2002 03:14 AM
