Old 03-12-2006, 01:17 AM   #1
shak's Avatar
problem with flickering
My lilliput has been flickering under heavy bass. I don’t have a huge system, just a 10" wfr and 100 watt pioneer amp. The power to the Lilliput is from cigarette lighter source through the egg like wire that came with the monitor.
Any suggestions? Maybe some kind of volt transistor/resistor.
shak is offline   Reply With Quote
Old 03-12-2006, 02:35 PM   #2
shak's Avatar
bump
Old 03-12-2006, 02:46 PM   #3
MySQL Error
scott_fx's Avatar
http://www.mp3car.com/store/product_...roducts_id=138
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 03-12-2006, 08:06 PM   #4
shak's Avatar
Quote:
Normal input voltage: 6.5V to 30V (note: input voltage must be greater than output voltage by approximately 1.5V, for example the 12v output won't work with 12v input, see one of our other power supplies for that application)
My car has a volt reader and I get between 13v to 14.5v. If my voltage drops below 13.5 then the power is cut off? And then the car is off, the battery provides 11.5 to 12v, which would not be sufficient for the requirement for this devise.
Old 03-13-2006, 09:31 PM   #5
shak's Avatar
bump
Old 03-17-2006, 03:48 AM   #6
shak's Avatar
Problem with directshow filter and WMP EricE Software & Software Development 0 03-01-2006 11:38 AM
Car Idle - power/amp problem? TheFaze Car Audio 1 12-16-2005 12:10 AM
A little problem with my car... Maybe... BoyNextDoor Power Supplies 30 11-13-2004 09:58 PM
Lilliput TouchKit problem solved! AAVfReaK LCD/Display 2 10-16-2004 04:51 PM
cordless phone problem jstrain Off Topic 2 06-24-2003 12:09 PM
