Old 03-12-2006, 06:24 PM   #1
Unhappy Lilliput problem: Fades to white then black
I took my Lilli apart to mount in a bezel, now when I plug in the power cord, the screen starts with white dots that grow to cover the screen, then black dots grow to cover the screen. I tried reseating the ribbon cable, but nothing.
Here's what it looks like:
Any help is appreciated.
PootsworthIII is offline   Reply With Quote
Advertisement Sponsored links
Old 03-12-2006, 06:34 PM   #2
My man uses Levitra.
Peoples's Avatar
ugh......i havent had to take my lilliput apart yet.......but now i do (****in touchscreen went retarded in a matter of minutes)......anyway......did you make sure the ribon is all the way to the left?.....its mis-sized
PC Components:
My work log
Peoples is offline   Reply With Quote
Old 03-12-2006, 06:36 PM   #3
Actually mine goes up and down, but I'll try to put it to one side or the other. Good luck with yours. Very disheartening to power it up and get nothing.
Old 03-12-2006, 06:44 PM   #4
Peoples's Avatar
mines been doing good for just under a year now.....i've actually had the monitor a little longer then that.....but the PC has been installed since easter of last year............the left side of the screen doesnt respond now
PC Components:
My work log
Old 03-12-2006, 06:46 PM   #5
Raw Wave
shotgunefx's Avatar
Not sure what to tell you, but I get something similar sometimes when switching modes.
I also noticed that happened today when I was cranking the car. What are you powering it with?
shotgunefx is offline   Reply With Quote
Old 03-12-2006, 08:03 PM   #6
is that a common thing that happens after a few years of use?
SleepingZ.com website of the Camaro
LS1Tech.com member, sycotic_reject
...noob...for now :)
sycotic_reject is offline   Reply With Quote
Old 03-12-2006, 08:08 PM   #7
Right now, straight from the ac/dc converter. It's out of the car. Same one I've been using to test the system with. But it does make me wonder if it's a power problem, not a ribbon cable problem.
Anyone else know anything about the ribbon cable mount not being fit right? I've had mine for over a year now with no problems, guess I'm not so good at getting this thing back together.
Old 03-13-2006, 10:29 AM   #8
bump for Monday
Old 03-13-2006, 07:48 PM   #9
Raw Wave
shotgunefx's Avatar
Quote: Originally Posted by PootsworthIII
bump for Monday
Poot, you suck. You jinxed me
I took out my lilliput to test out the glare screen and I've got a very similar problem now.
Old 03-13-2006, 08:57 PM   #10
Raw Wave
shotgunefx's Avatar
Fixed it.
My lilliput won't work until it's near 45 degrees upright.
Give it a try as it looks like you layed it flat out too.
update, actually around 30 degrees.
Old 03-13-2006, 09:30 PM   #11
poot,
this might not help, but i had similar symptoms. i got the white dots growing around the screen. what would happen was that it would be turned on and fine. then one of two things happened. either the screensaver kicked on, or windows would shut off monitor (from the control panel/power options/ turn monitor off : after x mins). but since you can't even get it turned on, this probalbly won't help. maybe a power issue you like i said. i just thought i would throw that out and in case it helps.
epdaniel is offline   Reply With Quote
Old 03-14-2006, 10:18 AM   #12
Thanks guys, I'll try these things when I get home and update you.
Old 03-14-2006, 10:53 AM   #13
Raw Wave
shotgunefx's Avatar
A little update. It wasn't the positioning that was causing the problem (which I thought was really weird), it is indeed the wiring. If it gets twisted just so, I get the problem you have.
Old 03-14-2006, 12:06 PM   #14
Which wiring? The ribbon cable?
Old 03-14-2006, 04:57 PM   #15
Raw Wave
shotgunefx's Avatar
The main cable harness that plugs in the back of the unit.
SUPER 7" Touch VGA screen, problem with drivers- same apps as Lilliput?... HACKTHS LCD/Display 2 07-22-2005 02:17 AM
lilliput display problem - RGB lines warnockm LCD/Display 10 01-06-2005 06:11 AM
TV-out only displays video in black & white, black borders on top & bottom, HELP! prospero LCD/Display 11 01-05-2005 12:24 AM
SV24 only outputs black and white to TFT B3AND1P General Hardware Discussion 8 06-11-2002 09:34 PM
riva tnt2 with tvout black and white on first startup gerard General Hardware Discussion 3 07-26-2001 04:48 PM
