Old 03-12-2006, 06:32 PM   #1
NeX
NeX is on a distinguished road
Problem with LinITX 7" TFT
Hello all,
i have a linITX 7" TFT and when i boot the pc and push the power button on the screen to switch to VGA mode the screen shows the pc for about 1 second and then switches off. but if i start the car then the screen stays on...
does anyone know if the screen has some sort of low voltage shut off?
is there a fix for this problem?
thanks ppl
NeX is offline   Reply With Quote
Old 03-12-2006, 06:45 PM   #2
MySQL Error
Scouse Monkey's Avatar
Scouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud of
no idea. this is an odd one. Could certainly be a voltage issue. try putting a meter accross the power lines to see what voltage you are getting. your battery could be struggling or you could be getting a voltage drop somewhere in the run to the screen. How are you conencting it to the battery?
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
Scouse Monkey is offline   Reply With Quote
Old 03-12-2006, 06:57 PM   #3
meyer64
I have a linITX screen and this happens to me every now and then. It only happens every two or three months or so. For me all i have to do is cut all power to the screen and then re-apply power and it turns on fine. I have never pinpointed the cause, but since it happens so infrequently I didn't look very hard either.
System: AMD Duron 1200+ , 512 MB ram , usb sb mp3+ , Tview 7" touchscreen , M1-ATX PSU , Slot Load iMac DVD-Rom , 40 GB laptop HDD, netgear USB 802.11g
Progress: Installation: 90% Dash fabrication: 80%
Parts Needed: USB GPS
meyer64 is offline   Reply With Quote
Old 03-12-2006, 07:33 PM   #4
NeX
thanks for the replies,
i have a set of switches that have a constant 12v supply and a 12v supply that comes on with the ignition. when i switch something on like the PS2 etc the double pole switches send power from either the 12v constant or the 12v acc to the screen and the device that i want to switch on.
so the screen isn't always connected in the same way each time.
i'm thinking its a voltage drop because the amps are on and the pc as well as the screen and the HU, i'm just wondering if anyone has had to use a capacitor or a voltage stabiliser to keep things running?
i'm upgrading to an Optima battery later on and the one i have at the mo is pretty pants, if i leave the headlights on for a few minutes then the car won't start.
still the screen shouldn't need too much power should it? like i said it does switch on for a second but it's as if it doesn't detect the pc signal and switches off. its never happend when the engine is running....
Old 03-12-2006, 08:21 PM   #5
MySQL Error
I doubt a cap will work.
Old 03-13-2006, 02:45 AM   #6
NeX
the other thing is that when the screen is switching itself off there is still plenty of power in the battery to crank the engine.
LinITX 7" Monitor James141 LCD/Display 4 03-17-2005 10:17 AM
WTB: XENARC 700TSV™ 7" TFT LCD Monitor w/ VGA & Touch Screen bd3521 Classified Archive 1 01-22-2005 09:03 PM
FS: 7" TFT Video modules (12pcs) - $60 shipped digitalww Classified Archive 64 12-28-2004 11:48 AM
Help solve my resolution problem on my 7" Lilliput!! CDL0012 LCD/Display 0 06-15-2004 12:01 AM
