Old 05-02-2006, 01:18 PM   #1
double-0-newb's Avatar
double-0-newb is on a distinguished road
Thumbs up Answered: Screens & Square VESA 75/100?
Hello,
I am about to order a 4.75'' Square VESA 75/100 Compatible Plate from
http://www.gpscity.ca/item-ram-mount-vesa-75-100-compatible-monitor-plate-with-1.5''-ball/ram246.htm
and I would like to know if the Xenarcs, Lilliputs and others have this same mounting pattern?
Searching and looking at pictures (like this one http://www.digitalww.com/VGA_TM_710VG.htm)
either confused or did not answer that particular question.
Anyone? Thanks in advance.
1998 Volvo V70 "Volputer"
Worklog: planning and procurement.
http://www.mp3car.com/vbulletin/worklogs/75505-1998-volvo-v70-now-libretto-100ct.html
double-0-newb is offline   Reply With Quote
Advertisement Sponsored links
Old 05-02-2006, 02:56 PM   #2
Banned
Motorcity's Avatar
Motorcity is on a distinguished road
A VESA mount is a standard size, but usually only found on 12.1" and larger lcd monitors. I highly doubt the smaller 7-8" units out there will accept a VESA mount.
Motorcity is offline   Reply With Quote
Old 05-02-2006, 03:50 PM   #3
Thanks Motorcity.
So if I did want to use one of those mounts to hold one of those monitors, it should not be too big a deal for me to simply remove the back panel, line-up the and mark the holes placement and drill and mount? Think there would be enough clearance between the plastic back and the guts for some nuts/bolts?
http://www.mp3car.com/vbulletin/showthread.php?t=75505
Old 05-02-2006, 03:57 PM   #4
nameeri's Avatar
nameeri is on a distinguished road
NO!! There is no spare room for mounting brackets or hardware on the back of these small screens. the LCD controller board rests against the back of the plastic case. Do not use a VESA mount on small monitors.
Civiputer: Dont have one anymore, but here is what is used to be!
nameeri is offline   Reply With Quote
Old 05-02-2006, 08:17 PM   #5
Mimicking my 2 yr old "But, I wanna!"
Ok, thanks for that info nameeri.
Any suggestions then? I was planning on mounting my "unit" (still in development phase; either Libretto100CT or iPAQ or small laptop monitor) just in front of my vents in my Volvo V70, and I would like it to be adjustable and pivot to face the passenger. I am going to swap-in a single DIN HU and use the open space to fashion a plate onto which can mount a bracket, 9-inch arm, then the pivot VESA head. The VESA head I thought would be ideal for either the Libretto or laptop screen (with mods), and wanted to know about the future-upgradability to a Lilli or Xenar (or other) keeping that same mount.
Pic of my planned install
Pic of parts to be ordered (note how some are were just carted out of interest)
Old 05-02-2006, 11:46 PM   #6
nameeri's Avatar
Whatever monitor you purchase will come with a mount, a small one anyways for it to rest on a table. usually, these mounts come in two or 3 pieces. The first piece fits onto the back of the display. The second piece (or 2 pieces) make up the arm which attach to the 1st piece. If you fabricate some sort of arm, you should be able to use the mount pieces that you get.
Old 05-03-2006, 08:12 AM   #7
Great. Done. Locked (if I can find that button...)
FAQ: VGA vs. Composite (Video) Screens cproaudio The FAQ Emporium 2 12-28-2007 12:45 PM
