Old 05-13-2006, 09:02 PM   #1
Xenarc causing noise (powering issue)
Ok, so I just got done with installing my Xenarc screen. I am getting a small line noise issue when the screen gets a signal (beit from the AV2 input or the computer). So the noise comes through my speakers only when the LCD gets a signal.
Now the Xenarc is directly wired into my cigarette lighter (just lopped off the end) and the connection is solid and a good ground as well. It is NOT the comptuer causing the noise as well because even when I didn't have the computer it would make the noise with the AV2 input.
1. Do I need to give the Xenarc regulated power? I don't think so because it handles this internally -- it must because the cigarette lighter adapter has no electronics in it and they intend you to hook it directly into your car then.
Thanks, any ideas will help!
PS: There is also another issue where the AV2 doesn't come on automatically when sensing a signal (if the monitor is in standby) but I'll start another thread on that.
davem is offline   Reply With Quote
Old 05-14-2006, 05:50 AM   #2
I have the same problem with my Xenarc. Wrote to their support and they told me to turn the volume all the way down.
Henk Bos is offline   Reply With Quote
Old 05-18-2006, 08:45 PM   #3
I have the exact same problem! The noise would go away everytime i restart the monitor. Then about 30 seconds later it will start to come back!
I already turned the volume all the way down to zero! HELP!!!
Honda Lagreat Carputer Project. Mobile Entertainment
http://www.mp3car.com/vbulletin/show-off-your-project/33936-honda-lagreat-carputer-project-lots-pics.html
Full Spec for mods check out:
http://www.hondashowoff.com/profile.php?id=3766
lookinco is offline   Reply With Quote
Old 05-20-2006, 09:35 AM   #4
The volume to zero trick worked for me! Thanks.
Old 05-20-2006, 03:01 PM   #5
I fixed it, i unplugged the speaker wire inside the xenarc!
http://www.mp3car.com/vbulletin/showthread.php?t=33936
Opus 150 Causing Drain or Bad Battery? Maybe 5vsb Issue? JasonWW Power Supplies 19 05-15-2006 01:54 PM
Power issue with Xenarc agent4877 LCD/Display 2 04-18-2006 12:10 PM
Powering new Xenarc 7" -Dead Avatar Monitor alexvr1 LCD/Display 0 04-18-2006 03:53 AM
xenarc gain causing RF interferance fishy LCD/Display 2 12-30-2004 05:36 PM
Lilliput causing engin noise eazyrog LCD/Display 10 06-07-2004 08:58 AM
