Touchscreen will NOT work
Alright, Ive searched and searched, and even found the post about the TS being a soldering problem. I have no idea what else to do.
So, I bought this Lilliput from mp3car store, installed it in my car. I did not touch any of the cabling with a soldering iron, and when I went to make it touchscreen, it wouldnt work. Turns out that the connector (mid cable barrel connector) had a bent pin. I straightend it and alls well. It works fine.
Then it stops working. I upgrade the software and THAT fixes it, it works fine. Then it craps out and now nothing will bring it back. Everytime I plug it in, Windows XP says 'unknown USB device) If I install the drivers, the software sees nothing on the USB side. If I manually install the drivers, it says that there are no devices that need those drivers.
So, Im at a dead end.
Heres my question, anyone know a fix? OR where I can order a female USB to female RS232 (Serial) so that I can go through the COM port rather than USB OR where I can order a whole new cable, from the screen to the computer?
Im at a dead end and completely stuck right now.
Thanks.
