Old 06-24-2006, 08:05 AM   #1
z8man is on a distinguished road
Xenarc color problems
So I am fitting my Xenarc 700TSV screen into my stock gauge bezel and had to dissasemble the xenarc screen and solder wires inbetween a connections inside the housing to make it fit the stock bezel. Well in all that soldering I must have messed something up because now it looks like this:
Im thinking I messed up one of the color channels but im not sure which one. Also, provided thats the problem, what wires should I look at as the culprits? I unsoldered the smaller board from my xenarc screen and extended it and that could be where the problem is. Any suggestions on what wire or what to do???
What can I say, I love Volvos:
Volvo 740 with 5.0 mustang conversion (crashed)
Volvo 740 stock (sold)
Volvo 940se
Volvo 850 T-5R yellow
z8man is offline   Reply With Quote
Old 06-24-2006, 12:31 PM   #2
ric355 is on a distinguished road
To get magenta you mix red and blue. Since anything that should show white is showing magenta in your image, that means the green channel is off.
I would suggest re-soldering all of your connections. Maybe you have a dry joint somewhere (i.e. looks like it is soldered, but isn't really). Given it runs off 12V you can open it up while switched on and poke around.
My in-dash screen recently did something similar. The flexible ribbon cable that connects the screen to the board inside the fixed part of the unit was not properly located. I had only the blue channel at one point. Relocated the cable and that fixed it.
EZSync - http://www.richmet.com/ezsync
ric355 is offline   Reply With Quote
Old 06-24-2006, 03:21 PM   #3
Anyone know what pin is the green channal?
Volvo 940se
Old 07-04-2006, 02:03 AM   #4
vinzer's Avatar
vinzer is on a distinguished road
take a standart VGA 15 pin connector pinout, trace from there the G (Green) pin and you will find it
BMW X5 Carputer Project
Finished: 85%
http://www.mp3car.com/vbulletin/show...lots-pics.html
vinzer is offline   Reply With Quote
Old 07-08-2006, 07:23 PM   #5
I found the wiring diagram, I traced the signal through the daughter board on the xenarc and it seemed fine to the point it goes to the main board. I decided to resolder my cable, so I removed it and did a much more thorough job of soldering it together. Still no green channel. Im thinking some sort of static discharge damaged the main board. I really dont know. Im at my wits end here and Im about to try purchasing another main board from xenarc cause I dont know where else the problem could be.
The screen still shows white in the menu and stuff, so it has to be something with the signal in, but I dont know what. I have a car show this weekend and was hoping to show off my carpc, but now it looks like ill have to wait a few weeks or months. damn it.
Volvo 940se
Old 07-09-2006, 04:35 AM   #6
anyone guys? Im a poor college student who dosnt want to fork over the dough for a new mainboard.
Volvo 940se
For SALE: Modified Xenarc MOLDED into Accord 98-00 console. Profes. Job 98 99 00 01 yunusyu Classified Archive 10 03-08-2006 03:44 PM
xenarc first impressions, tried lilliput before emdzey01 LCD/Display 7 06-09-2005 07:26 PM
Basic Question: How do I get my computer to display on my Xenarc PDiddy General Hardware Discussion 11 01-13-2005 08:23 AM
Xenarc, Lilliput, Xenarc, Lilliput, Xenarc, Lilliput, Xenarc, Lilliput, Xenarc voidunknown LCD/Display 88 09-15-2004 06:38 PM
Xenarc Meta FAQ Skippman LCD/Display 0 08-23-2002 04:11 PM
