Old 06-25-2006, 03:02 AM   #1
scootabug is an unknown quantity at this point
Lightbulb Lilliput 639GL in 2-DIN?
Hi Everyone,
Been reading on your forum here for a while, figured you guys would know the short answer to this question:
Can you mount a Lilliput 639GL 7" Widescreen in a 2-DIN dash? I assume the dimensions of this would be about 179W x 100H x 190D. Width and height is what I am most concerned over (obviously!).
Some details I have found on the screen show the dimensions being 185mm Wide x 128mm High. What I need to know is, is this including the fascia of the very front of the screen, or does that extend further than 185 and 128mm? Check this pic for a reference: http://www.ex-audio.com/ebay%20pictu..._new_side2.jpg
Also this pic: http://www.ex-audio.com/Inventory/US..._touch_new.jpg
So long story short, could you get this screen to jam into a 2-DIN dash with a little cut-and-shut, or would it be a messy task?
Any info would be great. Thanks a lot.
Cheers,
Scoota
scootabug is offline   Reply With Quote
Advertisement Sponsored links
Old 06-26-2006, 02:13 AM   #2
Bump!
Old 06-26-2006, 07:06 AM   #3
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
You're going to be doing a bit of fabrication work. How much fabrication depends on your vehicle's dash and how you want it to look when you're done.
There's a thread in teh FAQ Emporium named "Everything you want to know about your Lilliput". I suggest searching it out and reading it, as well as any other threads in the FAQ Emporium. You can't have too much knowledge.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Lilliput 7" Cable help needed. (Bad 9pin DIN) FireAnt LCD/Display 33 11-12-2007 11:34 AM
Possible Lilliput Double Din Mount? sheerdark Fabrication 19 08-06-2007 12:32 PM
WTB: Lurker needs 9-pin Mini Din cable for lilliput Zeroaviation Classified Archive 2 04-10-2006 01:42 AM
Help!! 8" Lilliput din SAME COLOR WIRES!!!!! Bizzar LCD/Display 1 03-31-2005 09:12 AM
8" lilliput in a double din? mykolJay LCD/Display 13 06-19-2004 10:07 AM
