Old 04-21-2002, 06:48 PM   #1
Registered User
etrik
allen's controller question
im using allen ruble's controller with my 8.4 in tft. all of the controlls work on the controller except "H pos" anybody got any ideas why this is? also if i wanted to hook my inverter through the card which pins would hook to what? (right now i am stealing 5v from the comps psu). thanks,
etrik
"if everything is under control, you're not going fast enough!"
etrik is offline   Reply With Quote
Old 04-22-2002, 07:58 PM   #2
claylong
As for the BL (backlight) inverter part, I don't think anyone around here knows exactly how that works. There is a thread in the LCD section that has been revived, http://www.mp3car.com/vbulletin/show...&threadid=5407 , and does have a little info on the pins.
Let me know if you find anything.
System in the works:
Celeron 850 or PIII 933, SB Live! Value into a stock 4 channel amp, ATI vid, 10.4" sharp LCD w/ allen's controller, Elo SW touchscreen overlay and controller, GPS, TV tuner, FW DVD drive, 4 port serial card, and some other stuff....
Loads of ideas.
claylong is offline   Reply With Quote
Old 04-23-2002, 02:29 AM   #3
Fosgate
Its simple really...
THere are 5 pins.
two 5v (even though one is around 4.6v)
one 10v
one ground
and one control
I got it working with my LQ9D023 screen that came with the standard backlight inverter.
however the inverter need somthing like 6-7v to operate.
I tried using the 5v rail but it was too bark tried the 10v rail and nearly burned the inverter...
around 7 volt makes it perfect.
I can adjust the brightness and everything...
Fosgate
System Comp V3 - In progress.
Low power MB with C7 CPU, DC-DC PSU, car ECU link, USB TV, GPS, 7" TFT, Wireless, Voice.
Fosgate is offline   Reply With Quote
Old 04-23-2002, 02:42 AM   #4
Cyberphox's Avatar
Cyberphox
Even simpler..I want one of Allen's controllers...sell it to me and solve all your headaches
Cyberphox is offline   Reply With Quote
Old 04-23-2002, 08:02 AM   #5
claylong
Not bad. Do you know if that is the order of the pins as well?
Loads of ideas.
Old 04-23-2002, 09:09 AM   #6
Registered User
mp3z24's Avatar
mp3z24
Quote:
THere are 5 pins.
one 10v
one ground
and one control
alright... then kindly share what pins are what values
i know a couplse of people that would love to have that info.... myself included!
~mike
Single Member of the "1000 Post and No MP3 Car" Club
PROJECT ON INDEFINATE HOLD... BOUGHT A HOUSE
2000 Cavalier Z24 [###-------] Only 30% Done ... Still
mp3z24 is offline   Reply With Quote
Old 04-23-2002, 01:22 PM   #7
pigseye
MP3Z24 is correct.
I would also like that info please.
Thanks,
pigseye
pigseye is offline   Reply With Quote
Old 04-23-2002, 09:45 PM   #8
Fosgate
I sure can ...
From memory its goes like this
======= Edit =======
Pins:
1 GND
2 10V
3 4.96v (5v)
4 Control
5 4.47v
Looking from the PCD (non component side).
THis is from the memory, when i get home I'll have a look at the pin numbering and will let you know exactly.
The control voltage goes from 0v to +5v
Note: I found that the standard Inverter that comes with the LQ9D023/LQ9D02C doesn't work with any of those voltages. THe control is ok but the running voltage is not in the range.
I suspect that the inverter requires around 6-7v to operate.
The voltages from the controller are either too high 10v or too low 5V.
Fosgate
