Old 08-04-2006, 06:29 AM   #1
356Speedster's Avatar
356Speedster is an unknown quantity at this point
1st Build - Monitor Advice...
..Yes, another noobie, I can hear you all groan from here!
First a brief background. I have a background in PCs & middle of the road car audio installation (amps, customs sub enclosures, nothing major), but after a year's worth of pondering and reading forums / web pages etc, I fancy giving the car PC thing a shot. According to my wife, I'm too old to be doing such things and should leave car PCs to younger folks.... but what does she know! I'm a bloke in need of a new project / hobby. I'm not sure that an Jaguar S-Type is the most appropriate recipient of a car PC, but I'm going to give it a shot anyway!
Currently, I'm sourcing a 2nd hand glove box and will use that to cut / shut and assess it's suitability for housing a mini-ATX custom PC. I'm also researching power supplies, cases and motherboards, but one thing that I could do with some advice on, is the TFT screen.
I'm quite lucky in that my dash houses a double-din stereo and next to it is a built-in pop-out mobile phone. I won't need the stereo (I'll put an FM tuner in the PC) or the phone (I'm hoping to have a PC Bluetooth connection to my main phone), so I'll have a nice big hole in the dash slightly higher than stereo and almost twice as wide to play with.
I want a factory looking install (whilst it won't exactly match an original Jaguar sat-nav install, it needs to fool casual observers that it is in fact factory), so it'll only be the screen that goes in this space and everything else will be hidden in the glove box. I'll build a custom bezel for it (I've fabricated a centre console for another car in the past, so this doesn't worry me too much!) which I'll need to match to the climate panel.
My issue is which screen to go for? I am looking for as large a touchscreen as I can fit in the gap (height will be the determining factor here and I need to do some measurements), that ideally doesn't have any buttons on the front of it, or has a panel I can remove. I will be fitting an intelligent PSU and whilst I want the PC to have a shut down delay after the ignition is turned off, I would like the screen to go off immediately (for security reasons).
As I'll be controlling the PC & volume via the touch screen, I would like a screen without buttons (or that I can remove), but I'm not sure if that's going to be possible given my wish to have the screen go off with the ignition, but the PC stay on for a while.
What are your thoughts on this? Am I asking too much? I did read that if some touchscreens are shut down before the PC, it can upset WinXP (my preferred OS)..... I'd welcome your thoughts / recommendations on this.
Thanks,
Mark
Jaguar S-Type - Crying out for a CarPC
Chesil Porsche 356 Speedster - Too basic for even a stereo
Mazda MX5 1.8Is - Wifey's wagon, thrashed regularly by hubby
356Speedster is offline   Reply With Quote
Old 08-04-2006, 10:00 AM   #2
bencrundwell's Avatar
bencrundwell is an unknown quantity at this point
Having the LCD turn off early should not be a problem. I have no isssues with my Lilliput, but even if you do, the lilliput has a totally separate touchscreen interface and PCB so you could always link the power of that into your PC power supply
bencrundwell is offline   Reply With Quote
Old 08-06-2006, 04:28 AM   #3
Thanks very much for your advice, I shall get cracking now..... although I think the glove box is going to need my attention before the screen. I'm having a major nightmare getting hold of a second hand Jaguar glove box, so it looks like I'm going to have to make a mold of mine and fabricate a duplicate to house the PC.
Looks like a LOT of house in the garage!
Cheers,
M
Does anyone want to build a fiberglass mold? SecretSpyder Fabrication 6 11-09-2007 05:10 PM
97 Toyota Tacoma You gotta See This. NEW UPDATE with 100+ pics on 7-4-03 cproaudio Show off your project 97 09-18-2006 02:56 PM
1st 'budget' build in a Mazda 626 trebuchet03 Newbie 0 03-03-2006 09:47 AM
Build my PC? diddy0071 Newbie 9 07-11-2005 01:00 AM
