Old 08-10-2006, 04:40 PM   #1
godraj's Avatar
godraj is on a distinguished road
intel mac mini flickering screen
So I have a flickering screen issue on my car when I use my intel mini. I used to have a G4 mini which also had a flickering issue, but I fixed that by using regulated power for the monitor. All my units for CarPc are now powered by carnetix PSU including the USB hub. These are a few things that I've noticed:
1) No flickering when using PPC g4 mini; yes flickering when using intel mini.
2) No flickering when using intel mini powered by household AC power (everything else is still car powered)
3) Limited flickering when usb devices are unplugged.
4) No flickering at all when itunes is importing a CD. (WTF???)
Any ideas on whats going on and how I can avoid this?
Thanks in advance.
godraj is offline   Reply With Quote
Old 08-10-2006, 07:30 PM   #2
CarFrontEnd Creator
iamgnat's Avatar
iamgnat is on a distinguished road
I had a flickering issue with my Lilli. After futzing around with various things it turned out that my refresh rate was off. I fixed that and it cleared right up.
Otherwise, make sure that the power cable from the P1900 to the LCD is well insulated and your VGA cable isn't running around uninsulated power lines.
-dave
My pathetic worklog.
CarFrontEnd (now it's own sub-forum!!!!)
iamgnat is offline   Reply With Quote
Old 08-11-2006, 11:57 PM   #3
godraj's Avatar
Thanks for the advice. I tried everything mentioned and it didnt' seem to help.
But I did notice something else, when I run cpu intensive programs the flickering stops. Can anyone explain what's going on and has anyone else experienced this issue?
Old 08-12-2006, 08:09 PM   #4
godraj's Avatar
Just tried a duo instead of solo and the flickering and noise issue is worse. I'm really stumped. Any suggestions???
Xenarc 700TSV and the Intel Mac Mini DiscoNomad MacCar 8 04-26-2006 05:41 PM
Mac Mini + external battery + OPUS power supply naaman Power Supplies 1 05-25-2005 07:23 PM
Need ideas for mac mini install! shizzle Fabrication 14 03-26-2005 02:39 PM
How is this motherboard? Intel board inside.. sspiro General Hardware Discussion 5 01-16-2005 02:16 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
