Old 08-11-2006, 05:29 AM   #1
ayasystems is on a distinguished road
Touchscreen problem in Lilliput
Hi guys,
I have a Lilliput v2005 and the touch screen doesnt work.
When I push in the panel the computer send a beep but the pointer is still.
I tried to calibrate it but nothing.
The pointer is located in the down-left corner of the screen. When I click it open start menu but doesn't move the cursor.
May be the touch screen hardware has been damaged?
Anybody has have the same problem?
Sorry for my English, I'm Spanish.
Regards.
ayasystems is offline   Reply With Quote
Old 08-11-2006, 05:35 AM   #2
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
More than likely something is pressing the screen... Probably on the bottom left corner.
Have you opened it up? Have you spilled crumbs on it?
Old 08-11-2006, 05:39 AM   #3
Simy's Avatar
Simy is on a distinguished road
If its not what 2k1Toaster said then it may be your drivers.....
Make sure your drivers are installed and working properly (im assuming your using windows xp here) go here to see:
Start > Control Panel > Performance and Maintenance > System > Hardware > Device Manager > (Then look for your thouch screen in the list, I'm not sure what it would come up as, right now my screen isnt put back in one piece yet, lol.
If it has a red 'x' or a yellow '!' that may very well be your problem.
Anways hope this helps
-Simy
Carputer Status: 10%
Have: Dell L400 (700Mhz 32?RAM, 20Gig HD), 7" Newvision, Pioneer DVDRW/CDRW via USB
Need: Amp.
Simy is offline   Reply With Quote
Old 08-12-2006, 01:22 AM   #4
Banned
Motorcity's Avatar
Motorcity is on a distinguished road
look for debris, and install the latest drivers then recalibrate.
Motorcity is offline   Reply With Quote
Old 10-24-2006, 07:18 AM   #5
SmoL is on a distinguished road
Hi guys,
just wanted to say i'm having the exact same problem. Did anyone ever find out what was wrong here. Drivers installed ok, drivers updated and also installed ok, chagned res, changed refresh rates. Still nothing.
any hints?
SmoL is offline   Reply With Quote
Old 10-24-2006, 07:22 AM   #6
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Did you try any of the suggestions above?
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 10-25-2006, 04:50 AM   #7
yeah no avail. I didn't take apart the monitor yet though to look for crumbs as I only just got the screen and its still in its shrink wrap in case I need to return it...
Old 10-25-2006, 09:54 AM   #8
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
Eliminate all other possibilities like..shrink wrap! then calibrate. That'll fix it! (from experience )
treetop777 is offline   Reply With Quote
Old 10-25-2006, 03:29 PM   #9
scsirob is on a distinguished road
I had a similar problem with my transflective screen (an upgraded Liliput). I took the screen apart, and ran a #24 insulated wire on the left- and righthand side of the front half of the case. It's easy to attach on the inside by bending it around the plastic screw posts. No need to mess with glue or anything, it stays in place as-is.
The touchscreen originally lays on thin strips of felt tape. It now lays with it's edges on the wires, creating plenty of clearance between the touchscreen and the case. I can properly tighten the screws around the LCD as well as the case itself, and the touchscreen work great.
scsirob is offline   Reply With Quote
Old 10-26-2006, 04:37 AM   #10
thanks for the input guys!
I've taken off the shrink wrap, i didnt however take the case off in for fear of voiding the warranty (which I plan to do later but want to at least know I have a working screen first). I did however loosen the screws/take out from the back and tried it. No luck....
Lilliput Touchscreen Driver Problem. gleinz LCD/Display 2 01-12-2007 12:30 AM
Lilliput touchscreen motorized VGA screen audio problem mick0uziel LCD/Display 1 07-11-2006 11:51 AM
Lilliput Touchscreen Stops Working!!! L-U-R-C-H Input Devices 5 07-09-2006 06:30 AM
Interesting Lilliput problem. Touchscreen stopped touching Grimoire LCD/Display 4 06-11-2006 12:46 AM
Lilliput touchscreen controller problem JayKaye LCD/Display 11 05-05-2004 08:47 PM
