Old 08-11-2006, 11:18 AM   #1
HIGHGRADE is on a distinguished road
change lcd background color
Is there a whay to change the lcd background color from standard blue to red, i have an idea i am working in and i needs to be red, or is there and 2.5 or 3 inch lcds that comes with a red back ground
HIGHGRADE is offline   Reply With Quote
Old 08-11-2006, 11:20 AM   #2
Jahntassa's Avatar
Jahntassa is on a distinguished road
Doubtful. Never seen anything but blue or black.
Jahntassa is offline   Reply With Quote
Old 08-11-2006, 02:47 PM   #3
DJiK's Avatar
DJiK will become famous soon enough
I have a 2" diffuser from a small LCD screen.
If you shine red LED light on in, it'd turn into a red-lit rectangle.
$5 and it's yours.
For Sale: Carputer (CarPC) & RCA Y-Adapter
Newsflash: Take a look at my unsold stuff above, thanks!
Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
DJiK is offline   Reply With Quote
Old 08-11-2006, 09:03 PM   #4
FLAC is for flaccid
parksgm's Avatar
parksgm will become famous soon enough
What LCD?
What does the backlight look like?
What are you planning to use it for? Nightvision?
...more information would really help answer your question...
Short answer is just replace or add high-brightness LEDs to your LCD lightguide.
An amateur built the Ark. The Titanic was built by professionals.
parksgm is offline   Reply With Quote
Old 08-12-2006, 12:53 AM   #5
most lcds come with a blue background, is it possible to chage it to red. I want to put two of these small lcds in my break light and when you press the break the video signal would cut and you get a red background.
Is this possible
does anyone know where i can find a 2.5 or 3 inch screen with red background thanks.
Old 08-12-2006, 01:12 AM   #6
Banned
Motorcity's Avatar
Motorcity is on a distinguished road
Is this possible
Are you refering to the blank screen you see that is blue when you power up a small lcd?
As for using as a brake light, good luck with the local revenue generators. Once Officer Friendly sees that, you will be in for a DOT insperction, and a ticket or 2. How can you use a red lcd display as a brake light? there is no way you would have enough light output to even remotely qualify as a brake light during the day. Plus, you need to have a change in intensity, or else the effect would be light turning on your headlights. people behind you would not know you are on the brake.
Although it sounds like it would look trick if it was set up right, but I think you are asking for trouble if you drove a vehicle in the manner you suggest.
Just my 2 cents, not trying to **** in your corn flakes. Good luck
Motorcity is offline   Reply With Quote
FAQ: Transflective Technology nameeri LCD/Display 0 06-06-2006 11:26 PM
Lcd grounding issue, can't get rid of flickering diskey LCD/Display 4 05-23-2006 04:16 PM
semi-noob color change question... Tim97rs Centrafuse 5 07-28-2005 06:55 PM
Pinout Color Codes / Tables gummybear General Hardware Discussion 4 05-12-2005 04:05 AM
12.1 Backlit 16.7M Color TFT Analog VGA LCD *FS* citrus3000 Classified Archive 5 06-17-2002 06:24 PM
