Old 08-14-2006, 03:06 AM   #1
Xplorer's Avatar
Xplorer is on a distinguished road
From Lilliput to RNS-E (AUDI A6 1999)
For a while now i have my system running using a Lilli.
I wanted to give a factory look to my A6 Carputer. I had two options.
1. Get a double din cage and integrate the Lilli in the dash, then relocate the head unit in the glove box.
2. Get an Audi RNS-E sat nav.
Option 2 is a clean process, so I gave it a go. I will have to find a new input device, since the touch kit will be out of the picture.
The next step? Purchase the parts required.
1. RNS-E Sat nav. Found one on E-Bay in very good condition.
2. CAN BUS emulator (This is required for Audi A6 pre 2000 models). The best place to purchase it from http://www.kufatec.de/
3. Double din cage and climate control face. The colour of the RNS-E is soul black. I bought them from http://www.partsdealer.de/ , used but in excellent condition.
4. Antenna adapter and removal tools which are very easy to find.
So after two months waiting for parts, the migration process begun.
- CarPC: Lilliput 7" Touchscreen, VIA EPIA M10K, 512 MB's of RAM, 40 GB's HDD
-AUDI RNS-E
Xplorer is offline   Reply With Quote
Old 08-14-2006, 03:17 AM   #2
Xplorer's Avatar
Migration
Start point:
Remove the upper cover:
Remove the frame around the head unit and AC:
Insert the head unit removel tools:
Pool off:
-AUDI RNS-E
Old 08-14-2006, 03:27 AM   #3
Xplorer's Avatar
Migration
Heat unit removed:
AC removed:
Ash tray removed:
Shift stick cover removed:
Carputer in glovebox, needs to be taken out:
-AUDI RNS-E
Old 08-14-2006, 03:36 AM   #4
Xplorer's Avatar
Migration
Carputer Removed:
Panel below steering wheel removed:
Center console removed. At last, the single din cage can be removed:
The double din cage installed:
The RNS-E and AC installed.
-AUDI RNS-E
Old 09-30-2006, 06:45 PM   #5
gokee2's Avatar
gokee2 is on a distinguished road
damn homie. how much did dat oem sat nav cost? i know it was definitely hella clean. yeah it sucks cos the 1998-2000 A6s have like single-1.5 din and the 01-04 got double. Im getting prolly a 1999. If im lucky maybe a 2001 4.2L. So now, can u post screens of ur oem screen displaying your carputer?
gokee2 is offline   Reply With Quote
Old 09-30-2006, 09:17 PM   #6
audia4b6us is on a distinguished road
If you can get the 2001, that one has CAN and the RNS-E is much easier to retrofit.
audia4b6us is offline   Reply With Quote
Old 04-08-2008, 02:24 AM   #7
SPYROS is an unknown quantity at this point
Hey, i have an A6 1998 with 1 din and i am planing to do the same nice job like your's. Please tell me this: do i have to buy another klima or i can use mine?? thank's a lot
SPYROS is offline   Reply With Quote
Old 07-09-2008, 08:05 PM   #8
ariel_atom is an unknown quantity at this point
Hello
I do the same conversion as your but at the moment I struggling a little bit. I cannot put the gear cover plate back in the place.
Do you know the way to put it back and How you do that?
Do I need to trim or change this plate or outside center console unit?
In the conversion I change
1. from 1din to 2 din bracket
2. Climate control unit
3. Ashtray
Do I need anything else in this conversion.
Thank you
ariel_atom is offline   Reply With Quote
Old 07-09-2008, 08:13 PM   #9
Hi Xplorer
I did the same conversion as your. However, I cannot put the gear cover plate back into place. Do you have any suggestion how can I put the plate?
In the conversion i change
1. 1din to 2din cage
2 2din type climate control
3. 2din type ashtray.
there is just only a small clearance between ashtray and lower plate.
Do I need anything else or any part I missing for this conversion?
thank you
2002 Audi A6 Bose Integration bobbydude78 Car Audio 1 11-05-2007 10:07 PM
Audi A6 1999 Carputer Install Xplorer Show off your project 7 03-30-2006 04:19 PM
2001 Audi A6 ices11 Show off your project 9 09-20-2005 11:07 PM
xenarc first impressions, tried lilliput before emdzey01 LCD/Display 7 06-09-2005 07:26 PM
Audi A6 custom install carpc with fingerprint recognition ejdeleon Show off your project 26 07-07-2004 04:25 PM
