Old 08-17-2006, 06:40 PM   #1
Brib3 is on a distinguished road
Touchscreen interchangeable? YESSSS!!!
*updade: it works flawlesly after a line calibration. See post #10.
*I personally find the Xenarc touchscreen way better than the Lilliput one, not function as much as the picture quality between the two. I had a White screen Xenarc and a Lilli with no touchscreen so that's how I got to it.
Hi. I was wondering if I could use a 4 pin touchscreen from a 7" xenarc on a 7" liliput screen?
Any help on this is appreciated. Thanks
Brib3 is offline   Reply With Quote
Old 08-18-2006, 02:17 AM   #2
Z28CTYHNTR's Avatar
Z28CTYHNTR is on a distinguished road
Interesting, I was just wondering this too. Just got the wonderful white screen of death on my Xenarc so I was going to buy a Lilliput and transfer the touchscreen if possible.
2002 Camaro Z28
Z28CTYHNTR is offline   Reply With Quote
Old 08-18-2006, 03:06 AM   #3
LiquidKernel's Avatar
LiquidKernel is on a distinguished road
It's possible. All of those 4-pin touch screen overlays are interchangeable. The USB TS controller is the same on pretty much ALL LCDs. The Xenarc, the Lili and my eBay brand all use the same one.
95 Volvo 850 T5 • Konis • ECU @ 17psi • Orange Ambient-Light + LED Dash Lights • DigiMotive Dimmer • Custom LED Brake Lights • TSX HID Projector Retrofit • Hella Raintronic
Carpc: [▓▓▓▓▓▓▓] 99% Cleanup.
LiquidKernel is offline   Reply With Quote
Old 08-18-2006, 09:02 AM   #4
Exactly... there is a HUGE difference between the xenarc touchscreen and the lilli touchscreen (crap)
Old 08-19-2006, 10:50 AM   #5
Ok, so with 2 pins changed I managed to get the Xenarc touchscreen to work as it should as in, moving my finger towards the left side, the mouse moves towards the left side and so on. This is with the LILLI touchscreen controller and the Xenarc touchscreen overlay.
THE PROBLEM: When moving my finger on the touchscreen towards the left side, the mouse moves further than where my finger actually is. How can I fix this?
Old 08-19-2006, 02:50 PM   #6
Z28CTYHNTR's Avatar
Have you tried calibrating it with the touchscreen software?
2002 Camaro Z28
Old 08-20-2006, 08:16 PM   #7
Pablome's Avatar
Pablome is an unknown quantity at this point
I had same problem.
Wazzzzup? Visit my site for News, Forum, Download of music and movies and watever else at pawelwebsite.com
Pablome is offline   Reply With Quote
Old 08-23-2006, 09:18 AM   #8
So I can fix it. What setting should I be looking at when calibrating. It's just the width of the screen that does not correspond. Thanks, Alex
Old 08-23-2006, 06:45 PM   #9
Calibration will just ask you to touch and hold different corners of the screen where a little dot comes up.
Old 08-23-2006, 10:03 PM   #10
LOL I just figured it out right before checking the forum again. It is confirmed guys. IT IS WORKING. All I had to do was switch 2 wires out of the 4: with the white residue side (from the double face tape), left to right, I switched the first wire with the third (I thing the ribbon going in the LCD is reversed too). But it is working perfectly. NOW I only have to solder a VGA cable straight to the monitor and it will be working perfectly. I have found that the connector between the LCD cable and the VGA cable can cause flickering after a while. Needless to say that needs to be taken care of as well.
Xbox Media Center 2.0 and Touchscreen blckwdw General MP3Car Discussion 31 05-12-2009 09:51 PM
Touchscreen problems with nlite and minlogon Ascension WinNT Based 1 06-01-2005 06:18 AM
Blew dust off, searched, and still no touchscreen on Lilliput - help! TheSpatulaOfLuv LCD/Display 4 10-13-2004 10:17 AM
7" Lilliput for sale NO TOUCHSCREEN CDesigns Classified Archive 11 05-24-2004 10:47 PM
