Old 08-18-2006, 10:33 PM   #1
JasonWW is on a distinguished road
Any Info On the New 10.4" Lilliput at MP3CAR Store?
Here is the new Screen.
http://store.mp3car.com/ProductDetai...Code=MON%2D027
And Specs:
PHP Code:
Screen sizediagonal 10.4"
New TFT LCD panels from BOE-Hydis
Aspect ratio: 4:3
RGB dot resolution (H x V): 1024 x (RGB) x 768 = 2,359,296 dots
High-resolution display of up to 1600 x 1200 (H x V) formatted
VGA input (15 pin D-SUB)
Touchscreen input (optional): USB or RS232 interface
PAL/NTSC color system
Onscreen display control (Multilingual)
Full-function infrared remote control
2 RCA video inputs, audio input
Audio and video output optional
Built-in speaker
LCD Brightness: 170cd/m2
Contrast: 500:1
Operating voltage: DC 11-13V
Power consumption: < 10W
Dimension (W x H x D): 252 x 216 x 76mm
For computer displays, S-video, DVD, VCD, security systems, navigation systems
It looks to be a true 1024x768 screen since it has 2,359,296 pixels. That's the most I've seen in this size of screen.
The one thing that bothers me is the 170cd/m2 brightness. This seems like a very low number.
Is anyone using this LCD? Anyone have any more info at all?
I was just about to order a different Lilliput 10.4". It's a 800x600 model and it's brightness is a more common 350cd/m2.
http://cgi.ebay.com/ebaymotors/Lilli...5252QQtcZphoto
Here are some of it's specs:
PHP Code:
Display Screen10.4” TFT LCD
Resolution
1440000 pixels (800 x 600
Brightness350cd/m2
Contrast
150
View Angle
100 degree 750 degree (horizontal vertical
Color system for videoPAL-4.43 NTSC -3.58
Sound system
100mW
Input Voltage
DC11-13Vpower consumption<=10W
Size
252(lx 216(wx 73(hmm (folding); 252(lx 186(wx 267 (hmm (unfolding
I don't know which would be better, really. I think the 800x600 would work well, but the 1024x768 would show more on the screen and can be run at a lower res if you wanted to. I just don't know. I may go with the brighter one as I already know for sure it will fit in my dash.
1999 Black Pontiac Trans Am
CarPC's in F-bodies
How to tune your sound system
How To Relocate Climate Controls on the 97-02 F-body Cars
(AMD Sempron 3000+, Opus 150)
Car PC system is out, Alpine system is in.
JasonWW is offline   Reply With Quote
Old 08-23-2006, 12:03 PM   #2
Just a bump in case any has some info.
CarPC's in F-bodies
Old 08-23-2006, 02:00 PM   #3
JuMpMaN6235's Avatar
JuMpMaN6235 is on a distinguished road
if anyone has this, Can you give me the dimensions of the screen only.. Not any of the plastic border
----][-][--][-][-I-][-][][][-][-I-][---][---][I--][
----][-][--][-][---][-][][][-][---][--][][--][-I-][
][][][-][][][-][---][-][-----][---][-][--][-][--I][
----------------------][-Carputer-|====|75%
JuMpMaN6235 is offline   Reply With Quote
Old 08-23-2006, 03:07 PM   #4
You didn't say which one. They could have different sized borders around the screen.
If your talking about the 800x600 one, there are pictures and dimensions in the main Lilliput thread. Just one person that I know of has taken it apart. Here's the link:
http://www.mp3car.com/vbulletin/show...1&postcount=45
If you mean the 1024x768 screen, I don't think anyone has info on it. It may be too new. I don't know.
CarPC's in F-bodies
Old 08-23-2006, 03:46 PM   #5
yea your right.. i think id want the one with more brightness..., i will most likely be using 800x600 anyways
Old 08-23-2006, 04:14 PM   #6
For some reason I doubt the 170 brightness. Maybe it's a misprint? That's why I wanted to get more info on it.
I'll probably get the 800x600, too, but just wanted to make sure.
CarPC's in F-bodies
Old 09-30-2006, 10:40 AM   #7
Another bump
CarPC's in F-bodies
Old 10-10-2006, 08:33 AM   #8
It looks like that first screen that had the low brightness has changed it's specifications. It now shows to be:
LCD Brightness: 300 cd/m2
Contrast: 200:1
BTW, I just got the 800x600 screen I posted above and I really prefer that resolution. Webpages are very readable. This screen however is not acceptable to me due to the narrow viewing angles.
In order for it to look right you almost have to look up at it or else have the top angled back. In my TA the screen is positioned straight up and down and is about gear shift level so I am looking slightly down at it. From this angle it looks really bad. I'm going to have to send it back and find another screen to use.
BTW, anything other than it's native 800x600 resolution looked really bad also. The only other screens I know of are 1024x768 and that may make the text too small. So it seems I'm screwed.
CarPC's in F-bodies
Old 10-15-2006, 01:06 PM   #9
I just heard back from MP3car store that the new specs on their 1024x768 Lilliput screen are now accurate:
Contrast: 200:1
and the earlier specs were incorrect.
Quote:
The viewing angels are: 45/60(U/D),65/65(L/R). However we haven't had a chance
to confirm them in our lab yet. The brightness is around 300nits and contrast
ratio is 200:1. The first specs posted were most likely inaccurate and the ones
I just mentioned more accurately reflect Lilliput's real performance. Besides
which, Lilliput just changed the LCD panels for the monitors so that had
something to do with it as well.
We are currently out of stock, but we have some LCDs on the way.
Sincerely,
Goce Evtimovski
Mp3car CS
CarPC's in F-bodies
7" Transflective monitor with T/S kit available now at the Mp3Car Store Zip-Lock LCD/Display 234 10-11-2007 10:25 PM
WTS: SP7 VGA 7" - Touchscreen (same as mp3car store has) BRAND NEW xcite Classified Archive 1 08-13-2006 06:48 AM
mp3car store has no warranty? 00christian00 General MP3Car Discussion 4 06-17-2006 04:34 PM
xenarc first impressions, tried lilliput before emdzey01 LCD/Display 7 06-09-2005 07:26 PM
Lilliput info required tolisn LCD/Display 1 02-05-2004 01:47 PM
