09-11-2006, 05:45 PM
#1
New DWW-750FM
09-11-2006, 06:49 PM
#2
Neither darque nor pervert
Vehicle: 2003 Toyota Tacoma X-Cab
You're angry because the new models of in-dash touchscreen are eschewing the complexity of the motor?
My Worklog
09-11-2006, 07:17 PM
#3
Is it too hard to make a good (may be not perfect) motorized monitor?
AG
09-11-2006, 09:01 PM
#4
AG
Nope, but it would be very expensive. A "perfect" motorized monitor would be adjustable left and right (eventually store it's position into memory for vertical and horizontal angle), this will increase the complexity of the monitor mechanism, this will involve then a high reduction of it's duration (or chance to get broken), to solve this problems you have then to use high quality materials and technology = high expensive monitor ...now what's the market of a hi-end monitor? Sure it is not for our "hobby". It would be a professional market, and if you look around you im sure you'll find one used on industrial enviroment (space shuttle? lol).... maybe you have to sell your car to buy one, but hey it is PERFECT!
09-11-2006, 09:16 PM
#5
Hmmm so you guys are recommending that I should get non-motorized in-dash. But isn't it a hassle to pull a non-motorized in-dash? Is there any video showing non-motorized manual operations?
AG
09-12-2006, 04:02 AM
#6
Vehicle: Focus ST
Dude, have a search around for the lilliput in dash motorised monitors and the problems they had and you'll realise why non-motoried is the best solution right now. To summarise for you; most, if not all were sent back as the motors froze. Manual monitors work by (when closed) you pushing the screen in which releases the lock and then pulling it out... Not really a hassle...
"This bloke said to me you haven't got a clue about the damage the soap bar can do to you,
I tried to see things from his point of view but I couldn't fit my head up his arsehole too."
09-12-2006, 09:17 AM
#7
AG
It's sure not easy as turn your key... but the question is: how much times you've to open/close your monitor? I've my carpc in use 90% of the time, i close it only when i park the car in the night or when i'm away from it (eg: in a bar.. disco...), then it wouldn't been a "whole day" repeated action.
09-12-2006, 11:53 AM
#8
Vehicle: 96 Pontiac Trans Am
I bought a motorized one for the 'aww' factor. I'm so ****ed I did. First time I tried to open it the screen got off track and jammed, took it a part fixed that. A day later the VGA ribbon cable got stressed from the opening and closing and broke a wire. (Why the hell would you use ribbon cables for something that needs to move anyway?!!) A week later I got the new cable, then broke the little connector for the panel side of the ribbon cable...I swear that thing is IMPOSSIBLE to get on. So I cut off an end of my old cable and stuck it on top of my new one and hot glued it in..(hey it worked..) But the part on how the screen wobbles back and forth about an inch when you press it annoyed me the most, I ended up pushing the tray back manually so the back of the screen can rest against the dash.
If I had it to do over I would buy a manual screen it a heart beat.
09-12-2006, 02:04 PM
#9
I thought these motorized problem were only limited to the ebay units and those purchased from DWW or MP3Car are fine.
Thank you guys for guiding me to the right direction.
AG
09-12-2006, 04:10 PM
#10
Vehicle: Focus ST
Couldn't say for definate but they (lilliput) put out a hell of a lot of ***** monitors before any working ones - getting people to basically beta test for them, nice...
There's just less to go wrong with a non motorised and what does a motorised one add apart from the "aww" factor????
09-12-2006, 06:43 PM
#11
Just a question regarding 750FM. If I connect a usb drive on external port of unit, it will be recongnized by the carpc attached....right?
AG
09-13-2006, 12:45 AM
#12
Vehicle: 90 RHD JDM 300ZX TT 2+2 5sp,92 MX3 GS-ZE, '00 Audi A4 2.8 Quattro, Ducati TT2 Replica
Other info that follows this same theme - http://www.mp3car.com/vbulletin/show...t=79168&page=6
Two single DIN, one of which appears to be transflective and 2 double DIN, one of which appears to be transflective. Haven't looked to see prices on these yet. Just to suggest that there are alternatives and similarly optioned units.
http://www.zenec.com/en_flash/index_flamonic.html
ZEM-W800DVD
1 DIN DVD Tuner with 7“/16:9 Widescreen TFT-LCD Active Matrix Monitor with integrated RDS Tuner
Multimedia in your dashboard - ZENEC's ZEM-W800DVD AV center is suit-able for installation in any 1-DIN radio bay. A high-resolution TFT monitor emerges at the touch of a button to display motion pictures in high-definition ZENEC quality. Listen to the radio, play CDs or MP3 audio files, watch DVD movies * ZEM-W800DVD is a versatile control center for your mobile entertainment system. The shockproof multi-format precision disc transport mechanism recognizes and plays CDs, VCDs, SVCDs, CD-R/RWs, compressed audio formats such as MP3 (with ID-3 Tag support) and WMA, as well as standard video formats such as DVD, DVD-R/RW, DVD+R/RW; of course, NTSC and PAL video source formats are both supported as well.
CD/DVD/MP3/WMA Features
DVD drive with electrical and mechanical anti-shock system
supports MP3 (ID3-Tags), CD, VCD, SVCD, CD-R/RW, DVD, DVD-R/RW, DVD+R/RW, DVD-MP3, WMA, JPEG, Picture CD
PAL/NTSC-compatible
Regional Code 2
graphical user interface, on-screen display
Display
motorized 7“/16:9 TFT LCD Active Matrix display
high resolution: 1440 (W) x 234 (H) pixels
generous viewing angles: left-right > 65°; above > 65°; below > 40°
300:1 contrast
Normal, Full and Wide picture aspect selection motorized adjustment of viewing angle with memory function
LC-panel protected against mechanical wear
automatic dimmer control
Tuner
AM-FM tuner with RDS
30 station presets: 18 FM and 12 AM
Audio
integrated 4 x 45 watts digital power amp
integrated Dolby Digital and Pro Logic II decoder
various DSP sound effects (Pro Logic II)
various audio EQ controls
A/V Connections
2 video outputs (RCA)
2 video inputs
1 video input (RCA) for rear view camera
analog 5.1 RCA audio outputs
2 channel preout rear (dual-zone)
Additional Features
additional Dot-Matrix LC-Display featuring blue illuminated segments with high contrast
Rotary volume control
multifunction stick for simple menu navigation
dual zone function
Tel. Mute
ISO connectors for power supply and speaker outputs
2 IR remote controls (front and rear) included
ZEM-W700DMM (Transflective?)
1 DIN 7“/16:9 Widescreen TFT-LCD Active Matrix Monitor with integrated RDS Tuner and TV Tuner
Multimedia in your dashboard - ZENEC's ZEM-W700DMM AV receiver is suitable for installation in any 1-DIN radio bay. A high-resolution TFT monitor emerges at the touch of a button to display motion pictures in high-definition ZENEC quality. The ZEM-W700DMM lets you enjoy radio, control CD and DVD changers and experience movies on the road. The receiver supports a wide range of AV sources: CD or DVD changers, cameras, etc. ZEM-W700DMM uses a newly-developed A-grade LCD panel with anan tireflective coating that enhances the contrast - a useful feature in extremely bright surroundings.
Display
motorized 7“/16:9 TFT LCD Active Matrix Display
Normal and Full picture aspect selection
horizontal angle of motorized display adjustable in three steps
intelligent dimmer control
RDS Tuner
automatic station search
TV Tuner
4-CH Diversity TV-Tuner
Audio
integrated 4 x 40 watts power amp
A/V Connections
1 video output (RCA)
2 video inputs
4 channel preout (front + rear)
1 AUX In
Additional Features
Sanyo bus control for external CD/DVD changer
Tel. Mute
ISO connector for power supply and speaker outputs
IR remote control included
ZEM-W600DVD
2 DIN DVD Tuner with 6.5“/16:9 Widescreen TFT-LCD Active Matrix Monitor with integrated RDS Tuner
Multimedia in the dashboard - ZENEC’s ZEM-W600DVD is suitable for installation in cars with 2-DIN radio bays. Listen to the radio, play CDs or MP3 audio files, watch DVD movies - ZENEC multimedia DVD tuner is a versatile control center for your mobile entertainment system. ZENEC’s ZEM-W600DVD supports a wide range of AV sources. The shockproof multi-format precision disc drive plays CDs, CD-R/RWs, VCDs, SVCDs, DVDs, DVD-R/RWs, DVD+R/RWs, MP3-Files, WMA-Files, JPEGs and Picture CDs ; NTSC and PAL video source formats are both supported as well. The ZEM-W600DVD lets you experience movies on the road: A high-resolution TFT monitor emerges at the touch of a button to display motion pictures in high-definition ZENEC quality.
supports CD, VCD, SVCD, CD-R/RW, DVD, DVD-R/RW, DVD+R/RW, MP3, DVD-MP3, WMA, JPEG and Picture CD
ID3-tag support
Regional Code 2
integrated Dolby Digital and Pro Logic II decoders
electrical (ESP) and mechanical antishock system
TFT-LCD Display
fully motorized 6.5“/16:9 widescreen TFT-LCD active matrix display
very high resolution of 1220 x 234 pixels
generous viewing angles: left-right > 60°; above > 30°; below > 60°
viewing angle adjustable (vertical)
RDS Tuner
AM-FM tuner with RDS and EON
36 station presets (18 FM, 18 AM)
BSM function (Best Station Memory)
A/V Connections
1 A/V input
1 video input
1 switched A/V input (Mono)
1 video output
4 channel preouts and subout
Additional Features
PAL/NTSC-compatible
graphical user interface with on-screen display (OSD)
Tel. Mute
plastic housings with scratch-resistant rubberized surface
ZEM-W600DDMM (Transflective?)
2 DIN 7“/16:9 Widescreen TFT-LCD Active Matrix Monitor with integrated RDS Tuner and TV Tuner
Multimedia in the dashboard - ZENEC’s ZEM-W600DDMM is suitable for installation in cars with 2-DIN radio bays. The ZEM-W600DDMM lets you enjoy radio, control CD and DVD changers and experience movies on the road. The receiver support a wide range of AV sources: CD or DVD changers, cameras, etc. The ZEM-W600DDMM uses a newly-developed A-grade LCD panel with antireflective coating that enhances the contrast - a useful feature especially in extremely bright surroundings.
TFT-LCD Display
7“/16:9 widescreen TFT-LCD active matrix display
very high resolution of 1440 x 234 pixels
RDS Tuner
30 station presets (18 FM, 12 AM)
BSM-function (Best Station Memory)
TV Tuner
integrated 1 channel TV tuner (Mono)
A/V Connections
2 A/V inputs
2 video inputs
1 video output
1 RGB port
4 channel preouts
Additional Features
PAL/NTSC-compatible
Tel. Mute
auto antenna control
Waiting on CT650 for +19 months to install my first CarPC 15/7/08
09-13-2006, 02:23 AM
#13
But no place to buy these LCDs. I don't think these are out yet.
AG
09-13-2006, 06:48 AM
#14
And not a one of those units has a VGA input.
And quit crossposting the same information in multiple threads, jschrauwen. Post it once and link to it in another thread if the information nees to go in both threads.
My Worklog
09-13-2006, 12:44 PM
#15
Vehicle: 2001 PT Cruiser
AG
According to the manual, it should.
| Thread Tools |
| Display Modes |
Linear Mode
