The MP3car.com Store
Thread Tools Display Modes
Old 12-11-2006, 07:10 PM   #16
morris_the_cat's Avatar
Vehicle: 2001 PT Cruiser
My Photos: (0)
There is no line out from this unit. I think I read in another thread for the double din with the dvd drive (made by the same company) that somebody bought some sort of converter from wall mart to convert the amplified output to a line output.
2001 PT Cuiser
VoomPC with 1.5Ghz C7
M2 power supply
in dash slim tray dvd drive
DWW-750FM c/w 7" USB touchscreen,AM/FM, 4x45W amp
See my install here
morris_the_cat is offline   Reply With Quote
Sponsored Links
Old 12-11-2006, 08:15 PM   #17
frankrizzo's Avatar
Vehicle: 2000 VW Jetta
My Photos: (0)
Scosche makes a multi-level line converter. I am using one right now with my monsoon stereo to add a line level out for my amp and sub. the 750Fm does not have line level out. it just outputs via the 45wx4 to the speakers. but then again, you could as mentioned, just add in a line converter. Why would you want to run radio into your pc anyhow, when it's already outputting? Unless your configuration is already established to use such a system.
Actually, it's the scosche SLC4
frankrizzo is offline   Reply With Quote
Old 12-11-2006, 08:26 PM   #18
frankrizzo's Avatar
My Photos: (0)
I am actually having trouble withthe drivers on win2k. It happened to misteriously work once totally fine. then i rebooted and it stopped. I keep getting a usb error. something about an improper driver. I'll be switching over to xp soon, but anyone have suggestions?
Old 12-11-2006, 10:11 PM   #19
My Photos: (0)
I am putting a stereo in my truck with equipment that I already have (amps, etc). Running just the radio off the internal 4x45 is not an option.
Anyone want a screaming deal on a DWW-750?
WTFover is offline   Reply With Quote
Old 12-12-2006, 08:49 PM   #20
frankrizzo's Avatar
My Photos: (0)
I'm not bein a dick or anything, but would you mind posting what kinda setup you have? maybe sketch it in paint or on paper and take a digital photo to post up?
Sponsored Links
Old 12-15-2006, 09:25 AM   #21
My Photos: (0)
It's a pretty standard car stereo setup. 3 Pairs of RCA jacks coming from the back of the head unit to the rear of the truck. You have front left+right, rear left+right, and a pair subwoofer out. The front and rear set of jacks run to my Mcintosh 4 x 25 amp. It has an internal crossover. The remaining pair of jacks for the Subs run to a MTX 1500D amp pushing 2 JLAudio 10w6 Subwoofers. This amp also has an internal crossover. Nothing earthshaking here, mine is probably just like a million other basic car stereo installs. The objective here is to replace my current HU with my CarPuter, without purchasing a switching device. I will probably end up just getting a line level converter for it and pumping it in to line in on the carputer.
Old 12-15-2006, 09:53 AM   #22
frankrizzo's Avatar
My Photos: (0)
I get yah..It's kinda hoaky no matter what. I'll be fallin in the same boat shortly after my last final today. I am deleting my stock HU and possibly factory amp (MONSOON) and using the 750FM. Since I am running a mono sub to a Punch 300.2 amp, I am gonna pull a RR and RL channel to feed it.your main issue is that no matter what you'd stil lneed a pair of line outs to the subs. Yah, i'd say go with the line level....but instead of going line in on carputer, the rca's on the 750 are in...not out.(From everything I've seen so far.) So why not jsut run all your systems INTO the 750 and let it handle all the switching. You can select audio during any video...ok babble now...good luck.
Old 12-15-2006, 10:34 AM   #23
hohenyi's CarPC Specs
Vehicle: Which 1????
My Photos: (0)
which cable from the 750fm will u used as the amp remote? Thanks
hohenyi is offline   Reply With Quote
Old 12-15-2006, 11:10 AM   #24
Vehicle: 1988 Porsche 928
My Photos: (0)
Quote: Originally Posted by WTFover View Post
...Anyone want a screaming deal on a DWW-750?
Well that depends on how screaming it is
I'm interested.....
aggravation is offline   Reply With Quote
Old 12-16-2006, 12:33 AM   #25
frankrizzo's Avatar
My Photos: (0)
not sure yet. I haven't fully planned it out or anything. currently I am still trying to get my touchkit drivers to work. as of right now my screen is a screen only with no touch input.! i am getting frustrated.
Old 12-16-2006, 01:56 AM   #26
My Photos: (0)
I recall that there was a link to the drivers for every major operating system on the digitallww product page. Have you tried that?
2001 PT Cuiser
M2 power supply
See my install here
Old 12-16-2006, 04:15 AM   #27
My Photos: (0)
the link at DWW to egalax does not work anymore had something to do with the co. being merge??? try this instead http://www.egalax.com.tw/web20/eg/drivers.htm
Old 12-16-2006, 10:51 PM   #28
frankrizzo's Avatar
My Photos: (0)
yah, i finally figured it out. I dunno why, i tried it on a different USB extension and BINGO! So now i dunno wtf. I am gonna check for damage to wire sheath and what not. seems odd though cause everything been workin fine. But I still have a lot of plans and whatnot for rewiring and crap, so i gotta see. Also, M_T_C are you running an amp and where did you pull the amp on?
Old 12-19-2006, 07:40 PM   #29
My Photos: (0)
Looks like you need to pull a line from the car ACC for the amp remote.
Old 12-19-2006, 10:45 PM   #30
My Photos: (0)
I am not running an amp. I am quite happy with the built in amp within this unit. I honestly do not see the point of using an external amp unless u have an existing system or want crazy power.
Hey, I wanna see some of the installs you other guys have made!
2001 PT Cuiser
M2 power supply
See my install here
Sponsored Links
vB code is On
Trackbacks are Off
Head to head shoot out of DWW in dash screens. belezeebub LCD/Display 0 09-15-2006 03:00 PM
DWW motorized housing plus xenarc/gain lostreception LCD/Display 4 04-06-2006 12:37 PM
FS: single DIN in-dash DWW TM-701L, non-motorized Tim97rs Classified Archive 14 06-27-2005 09:10 PM
700TSV--->single DIN pullout from DWW conversion questions Tim97rs LCD/Display 1 06-23-2005 02:18 PM
Anybody use this from DWW heartpumper LCD/Display 0 02-27-2004 09:08 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
