Old 09-25-2006, 11:10 AM   #1
yukon's Avatar
yukon is an unknown quantity at this point
M2-ATX, VoomPC - Advice needed for clean power connection
I managed to acquire a buddies Newision 7" LCD Touchscreen so I'm going to connect to my car PC power supply for power.
What I'm looking for is a clean way to connect it through a VoomPC.
I'll connect it to the Molex coming from the M2-ATX but I'm looking for a clean way to make it unpluggable so I can remove the Computer from the car quickly.
My idea is to somehow run the molex out the back (where all other connections are) so that I can use a male molex connector as the plug (coming from the lcd). I've got a VoomPC case so you can see, I'm sort of limited to where I can enter the case.
Has anyone done this? And made it look clean? Does it make sense?
If you have, can you post pics or reasonably hand drawn facsimile.
yukon is offline   Reply With Quote
Old 09-25-2006, 11:52 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Wire a male HDD molex connector to the power lines running to the screen.
That way you can disconnect the power at the PC end.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 09-25-2006, 11:59 AM   #3
yukon's Avatar
That's what I am planning to do but I was hoping someone else has done it so I can see what it looks like coming out the back of a VoomPC case and where the actual connection (from the lcd "molex" to the psu "molex") was connected. For example, I'd like it to basically look like the power connector that goes to the VoomPC case. Keeping it as "factory" looking as possible.
VoomPC, VIA C7 1.5 Ghz, 7" Newision LCD, 80 Gig WD 5400 RPM Laptop Drive, M2-ATX, RoadRunner, iGuidance, Freedom 2.0, AT&T Natural Voice Hot Babe Audrey. All wrapped up in a piece of crap Suzuki Grand Vitara.
Old 09-25-2006, 12:33 PM   #4
rsd212 is on a distinguished road
My VoomPC molex had open spots for more pins. Cant you just wire into that? I stole the 12V and GND off a drive molex inside, wired it to the VoomPC molex.
MII-12000 / Ampie / Lilliput 7" / BU-355 / PicoPSU / uSDC
Currently: Enjoying the setup, but always contemplating my next move...
rsd212 is offline   Reply With Quote
Old 09-25-2006, 02:04 PM   #5
yukon's Avatar
That's right, I completely forgot about that.
The VoomPC has a green and a black wire for "special Use".
I guess that I could connect the molex yellow to the green wire harness and the black to the black. Then connect the lcd 12v to the green wire and black to black.
Does that sound correct or have I been drinking too much?
ATX power supply question dudah85 Power Supplies 3 10-10-2006 05:49 PM
New PicoPSU-60 (6-26vdc input) ik632 Power Supplies 1 10-03-2006 12:18 PM
NIB M2-ATX DC-DC ATX auto car PC power supply mini ITX EPIA ichiban Classified Archive 6 07-21-2006 01:00 PM
help needed for lillput power off xinyuan LCD/Display 2 05-29-2006 01:22 PM
ATX Motherboard... power supply questions msreyes General Hardware Discussion 1 05-09-2006 09:01 AM
