Old 09-29-2006, 04:42 AM   #1
hohenyi is an unknown quantity at this point
Need advice on 7" indash before purchase.
have any one use one of this before. Would appreciate if someone could advice
VMI70A in-dash 7" TFT-LCD touchscreen PC VGA monitor
*NEW* direct from the factory
Features
7" TFT LCD touchscreen display
Resolution: 800x480 (native)
Supported Resolutions: 640x480-1280x768
Video Input: VGA input (15 pin D-SUB analog RGB interface)
4-wire resistive Touchscreen (USB interface)
PAL/NTSC color system
Full-function infrared remote control
On Screen Display Menu Control
Automatic display angle adjustment
High-Brightness CCFL Backlight
2 AV/RCA video inputs, 1 audio Input
3 month warranty
Package Includes
Remote control
VGA cable
AV cable
Power cable
Stylus
CD with touchscreen drivers
Operation manual
hohenyi is offline   Reply With Quote
Old 09-29-2006, 05:08 AM   #2
Cravex7's Avatar
Cravex7 is on a distinguished road
Post up a link or some pictures for a better responce as some monitors are re-named/re-numbered by different sellers.
"This bloke said to me you haven't got a clue about the damage the soap bar can do to you,
I tried to see things from his point of view but I couldn't fit my head up his arsehole too."
Cravex7 is offline   Reply With Quote
Old 10-01-2006, 09:26 PM   #3
Elifromthevi is an unknown quantity at this point
New In dash VGA TS for $325 what do you think
Link to store with vga,
http://www.short-circuit.com/details...rs/vmi70a.html
and the user manual
http://www.short-circuit.com/manuals/vmi70.pdf
Car PC Status {------- }0%
Car Died along with Autonode Monitor after returned to me. Worked for 3 Months then died again. The car engined died not long after!
Upgraded to 2003 Infiniti G35 Coupe
Exploring options of a double din unit style Car PC.
Elifromthevi is offline   Reply With Quote
Old 10-01-2006, 09:58 PM   #4
walstib's Avatar
walstib is on a distinguished road
That looks exactly like my SP-716, same manual with poor english translations. I'm pretty happy with my monitor. Some people have reported the plastic gears breaking, but mine seems fine. You may want to search on SP-716 here, there may also be other numbers for that screen.
Carputer Project Status:
0% - Mobo died on 2/17/08
Check out the worklog for my '01 Pathfinder.
walstib is offline   Reply With Quote
Old 10-01-2006, 10:12 PM   #5
yeah it does seem to be the same as the SP-716; How was your install, good or bad?
Old 10-02-2006, 12:56 PM   #6
walstib's Avatar
Elifromthevi,
The install was as easy as installing a head unit, solder power connections, 4 screws to mount to a frame, hook up UBS, video, etc., then bolt the frame to the car. It was kind of tight to put it on top of my new head unit, but that was just the A/C stuff in my Pathfinder. You can see pics in my worklog (see sig below)
Old 10-15-2006, 03:01 PM   #7
wes4u2nv is an unknown quantity at this point
[QUOTE=hohenyi;935151]Hi, I'm about to purchase a 7" indash for my car pc, have any one use one of this before. Would appreciate if someone could advice me on this thing. Thank You.
Features
Hi people.
I am also about to invest in this above touch screen monitor. looks and sounds the part but how have you people found it?
whats the quality like? and would you say it is reliable?
your response will be appreciated
cheers all
wes4u2nv is offline   Reply With Quote
Old 10-15-2006, 04:29 PM   #8
walstib's Avatar
No problems with mine...
Old 10-17-2006, 11:59 AM   #9
jermaine
seems I am the only one with problems on this screen.
bought it from ebay and the seller has dissapeared.
somebody knows yuki?????
jermaine is offline   Reply With Quote
Old 10-17-2006, 04:41 PM   #10
walstib's Avatar
Quote: Originally Posted by hohenyi View Post
Hi, does the thing have built in TV and FM? coz the operation mannual make it looks like it does. The diagram in the operation manual shows the unit is hook up directly to the car batt. did u followed or u used a DC to DC PSU. Please advice TQ in advance.
Mine has built in TV, no FM. The reception pretty much sucks for TV and I didn't even hook up the antennea for it once I mounted in the car. BTW, it's a PAL antennea and you will need an adapter you can get at radio shack(I think it is part# 278-261). There is a thread on that somewhere...
I have constant power to the batt and acc to the acc line, both with inline fuses. Seems to do OK for me. Your milage may vary.
Old 10-17-2006, 05:48 PM   #11
masch
Could it be that the reason the reception sucks is because the antenna is not connected?
New Lilliput EBY701 For Sale http://www.nusantech.com/index.asp?c...at=TOUCHSCREEN
SiRF3 Bluetooth GPS http://www.nusantech.com/index.asp?cat=GPS
masch is offline   Reply With Quote
Old 10-17-2006, 06:17 PM   #12
pepsibobby's Avatar
pepsibobby is on a distinguished road
sounds like a very valid point. lol
Cant code cause I dont know how, but give me the paint bucket and my eraser and have at you!
pepsibobby is offline   Reply With Quote
Old 10-18-2006, 02:23 PM   #13
walstib's Avatar
I hooked it up to a set of rabbit ears before installation in the car, when I was bench testing. The reception sucked so I didn't bother with hooking it up in the car.
Old 10-18-2006, 03:16 PM   #14
Gavitron is an unknown quantity at this point
Hi. I have little or no experience here, bu am looking to learn fast - My head-unit is dying, and I plan to replace it with a carputer. Still in the "Thinking" phase of the project though, (Saves money if this comes before the "Buying Phase"
So what I was wondering about this screen, is whether there is some sort of "firmware OS" (for lack of a better term,) that comes up before the PC comes on... I've seen a fair number of these in-dash screens, where there is a whole "Host OS" on it, designed to switch between inputs, and act almost like a head-unit. I think I would rather just have a "Passive" monitor, and let the PC do all the work of selecting inputs... Am I wrong in this thinking? Do I have to get a non-flip unit like the lilliput 7" for that sort of control, or is it available in a "dumb" motorized head unit?
Thanks,
-G
Gavitron is offline   Reply With Quote
Old 10-19-2006, 01:02 PM   #15
walstib's Avatar
I'm pretty sure there are motorized liliputs (or other) that are nothing but a touchscreen monitor. Look in the MP3Car Store, I think the Xenarc will do, also the MTSVO-SC.
You would then need a TV tuner card, USB radio, rearview camera, and everything else running on/into the PC and it would handle all the switching. Ideally, I think that would be the way to go. I only use the VGA input and touchscreen on mine, so the rest is really a waste, to me.
pyle 7" screen advice. Enigma04 Newbie 17 07-23-2006 08:51 AM
I need your help on which LCd 7" indash dvd mp3 player to buy JayDM03 LCD/Display 0 09-12-2005 01:49 PM
dual indash 7" monitors Johny_Dough LCD/Display 4 03-21-2005 12:24 PM
7" indash touchscreen VGA in UK spyda LCD/Display 0 03-06-2004 11:53 AM
FS: digitalww.com 7" indash din pocket samc Classified Archive 6 03-30-2003 09:51 AM
