The MP3car.com Store
Thread Tools Display Modes
Old 10-22-2006, 11:22 AM   #1
My Photos: (0)
Unhappy Touchscreen trouble in transflective paradise
I got my transflective screen delivered in record time, just 5 days to The Netherlands. Great! I spent the next two weeks building it into my little project. The display is very nice and bright, and a lot less glare compared to my previous DigitalWW screen. However, not all is good ...
The touch screen is acting up. It behaves like it's being constantly pushed somewhere in the upper left corner area. This makes it totally unusable.
I read some of the threads leading up to this screen becoming available, and this appearently was a problem initially. MP3Car initially delivered the screen without housing because it wouldn't work well with the touchscreen. They then found 'a fix' and now the monitor comes complete with housing. That's how I got mine.
For me it appears the fix is not enough. Looking at the way the front bulges, it's obvious that the touchpanel is really too thick to fit the housing. Loosening up the attach brackets isn't an option, as they are already so loose that the screws are about to fall out. It also makes me wonder if bumps and vibration wouldn't cause the touchscreen to act as if the edges are being pushed.
Can the touchscreen be replaced by another, thinner model without distroying the optic parameters? Are others seeing the same thing, and has anyone come up with some smart fix yet?
scsirob is offline   Reply With Quote
Sponsored Links
Old 10-22-2006, 04:33 PM   #2
sxott's CarPC Specs
My Photos: (0)
If that is the only problem buy some longer screws. Use some loctite. It does not sound terribly difficult.
sxott is offline   Reply With Quote
Old 10-23-2006, 02:24 AM   #3
My Photos: (0)
Just longer screws won't do. The screws are loose to the point where the LCD and touchscreen are almost able to move around. If I use longer screws and let them stay loose enough so there's no false readings then the LCD and touchscreen will be able to move around freely. I need a fix that will fixate the components but doesn't cause false readings from the touchscreen.
Old 10-23-2006, 11:17 AM   #4
nameeri's Avatar
Vehicle: 2003 Honda Civic
My Photos: (1)
Try putting some double sided tape along the very edge of the TS. Unstick one side and leave the protective backer on the other side. If you cut long slender pieces, put it all around the edge it should help the problem. I also have this problem with my TS and initially it was a real pain. The problem has since resurfaced and is causing me a lot of headaches. But I may just have to loosen the screws on the brackets some more.
Civiputer: Dont have one anymore, but here is what is used to be!
nameeri is offline   Reply With Quote
Old 10-24-2006, 12:27 PM   #5
My Photos: (0)
Thanks for the tip, Nameeri.
Instead of using tape, I have ran two strands of #24 wire on the inside of the frontpanel, one on each side. This way the very edge of the touchscreen lays on the plastic insulation of the wire and there's enough clearance to make the touchscreen work well. The screws can be tightened properly so nothing shakes loose when in use. You can still see the front panel bulge a bit, but at least the touchscreen works well now.
I'll post a couple of pictures of my project later on, so you'll understand why loose parts are not an option
Old 10-24-2006, 05:25 PM   #6
nameeri's Avatar
My Photos: (1)
Wire huh? maybe ill do the same. please post some pics if you have them.
Old 10-25-2006, 02:38 PM   #7
My Photos: (0)
I got no pictures of the inside itself, but I do have a picture of my little project. It's a RANS S6S Coyote-II. Six years and counting, built from kit. You like?? (BTW, screen is not the transflective one, I took this picture with the old DigitalWW screen in place).
Old 10-25-2006, 03:27 PM   #8
Laptop, Tablets, UMPC Moderator
turbocad6's CarPC Specs
turbocad6's Avatar
Vehicle: 2002 pontiac montana
My Photos: (77)
yeah.... now THAT'S a test of the transflective if I ever saw one
MY NEWEST INSTALL:modded infiniti fx with big screen - "If my typing sucks it's probably because I'm driving....................."
turbocad6 is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Hardware Review: Provision 8" 16:9 VGA Touchscreen lightman The Review Palace 18 05-21-2007 04:45 PM
2003 Saturn L200 In Dash Touchscreen Carputer snoslicer8 Worklogs 3 07-11-2006 09:57 AM
FAQ: Transflective Technology nameeri LCD/Display 0 06-06-2006 10:26 PM
USB Touchscreen Problem skeeter007 Input Devices 3 10-07-2004 02:49 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
