The MP3car.com Store
Thread Tools Display Modes
Old 11-01-2006, 12:00 PM   #1
shrinkydinx's Avatar
My Photos: (0)
two questions about larger-than-7" touchscreen monitors
(significantly larger, as in 10"+)
1) are there any available with the amazing transflective screen?
2) what frontend works with these larger resolutions?
carputer - done.
shrinkydinx is offline   Reply With Quote
Sponsored Links
Old 11-02-2006, 11:39 PM   #2
My Photos: (0)
no one?
carputer - done.
Old 11-03-2006, 12:42 AM   #3
Laptop, Tablets, UMPC Moderator
turbocad6's CarPC Specs
turbocad6's Avatar
Vehicle: 2002 pontiac montana
My Photos: (71)
THIS is a thread I did about some 10.4's... these screens are also available in 12.1's...
MY NEWEST INSTALL:modded infiniti fx with big screen - "If my typing sucks it's probably because I'm driving....................."
turbocad6 is offline   Reply With Quote
Old 11-03-2006, 11:54 PM   #4
My Photos: (0)
& did you make any posts about frontends?
carputer - done.
Old 11-03-2006, 11:58 PM   #5
XC-C30's CarPC Specs
XC-C30's Avatar
Vehicle: 1992 citroën AX MKII
My Photos: (0)
I think fron-ends should work on larger screens. I had centrafuse running on a 15" without any problems.
Xenia: pink princess
status:
In progress
STATUS:
'T SQiekenkot: No Car
hardware: 0%
software: 0%
audio: 0%
building: 0%
XC-C30 is offline   Reply With Quote
Old 11-04-2006, 12:16 AM   #6
Vehicle: 2006 NISSAN 350z
My Photos: (0)
hmm
listen if the transflective 7 inch runs for like 600 you are really going to drop some serious money on a 10 or bigger we are talking 1k or more for that much money you can get a no name brand lcd 27 inch from sears and hook it up to any computer you want i have a HD tv lcd 27 at home hooked up to my desktop and sometimes hooked up to xbox 360 work nice but trans thats some serious money
merk350z is offline   Reply With Quote
Old 11-04-2006, 09:37 AM   #7
turbocad6's Avatar
My Photos: (71)
the screen is the single most important end of a carpc, it's really all you see in normal use, & it is most of your interaction & control, as well as feedback...
in a sense, the screen IS the carpc... I'd rather have a killer screen with a few comprimises in the rest of the system than a crappy screen with a killer system, of course, best is to have it all, but the screen should take the highest priority as far as I'm concerned...
a killer large screen will be expensive, but well worth it
any frontend will work on a big screen, but sometimes, with extra screen realestate, you'll want to modify the skin to better suit, I mean with a large screen you can have more info available at the same time, & large buttons on a 7" can be too large on a 12.1, so the best thing to really get the most out of it, is to choose a frontend that you can alter to better suit.... but any frontend will work...
Old 11-04-2006, 07:04 PM   #8
My Photos: (0)
^ but you gotta put ****loads of work into changing the skin to your res...
carputer - done.
Old 11-04-2006, 08:48 PM   #9
turbocad6's Avatar
My Photos: (71)
no,... most frontends it's just a matter of changing a line or 2 in either a setup menu or worse case a system file...
you CAN stretch any skin to fit your resolution no problem...
it will work no problem......
if you want to do a ****load of work to better take advantage of a larger screen you can, but you certainly don't have too...
Old 11-10-2006, 02:08 PM   #10
jsdr78's Avatar
My Photos: (2)
Here is my 8.4' lcd Transflective with infrared glass touch screen. I sent this lcd panel to taiwan to add transflective and to make a infrared touch screen tampered glass.
jsdr78 is offline   Reply With Quote
Sponsored Links
Old 11-10-2006, 09:23 PM   #11
Iceman_jkh's CarPC Specs
My Photos: (1)
Looks nice .
Can that screen autoswitch to reverse camera (RCA)?
what resolution is it natively?
How much did it cost all up.
Iceman_jkh is offline   Reply With Quote
Old 11-11-2006, 02:09 AM   #12
jsdr78's Avatar
My Photos: (2)
Quote: Originally Posted by Iceman_jkh View Post
Looks nice .
Can that screen autoswitch to reverse camera (RCA)? it has rca, s-video volume controls input and output adn vga
what resolution is it natively?supports up to 1024X768 but i run it at 800x600
about 1k
Old 11-11-2006, 02:17 AM   #13
My Photos: (1)
cheers,
but does it switch automatically to the RCA when the RCA signal is present, and then back to VGA when the RCA signal disappears?
Old 11-11-2006, 02:18 AM   #14
Banned
Motorcity's Avatar
My Photos: (0)
Quote: Originally Posted by merk350z View Post
listen if the transflective 7 inch runs for like 600 you are really going to drop some serious money on a 10 or bigger we are talking 1k or more...
Wrong. You can buy a 10.4" touch screen with transflective enhancements for under 700.00
Motorcity is offline   Reply With Quote
Old 11-11-2006, 08:12 AM   #15
jsdr78's Avatar
My Photos: (2)
cheers,
I haven't try that, eventhough I bought a top of the line vga lcd controller. i really don't use rca and I am not planning on using it. i will you a camara in the computer via vga
Sponsored Links
vB code is On
Trackbacks are Off
Lilliput 7" Touchscreen Damaged?? munkynpunky LCD/Display 12 08-13-2006 09:07 PM
Need Help Running One Touchscreen Lilliput and Two Clarion Headrest Monitors? VAN~MZD~6 LCD/Display 3 07-18-2006 03:30 PM
New 17" Dell monito to trade for Xenarc 7" touchscreen thematrixz Classified Archive 3 04-27-2006 07:38 AM
WTB: 7" - 8.4" LCD touchscreen robiewp Classified Archive 2 05-25-2004 08:36 PM
7" Lilliput for sale NO TOUCHSCREEN CDesigns Classified Archive 11 05-24-2004 09:47 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
