Old 11-05-2006, 06:25 PM   #1
Cerztrueheart is on a distinguished road
Unhappy Xenarc 700tsv bsod? help.
greetings.
i've never had a problem w/ my touch screen before. i took apart my xenarc and mounted it into my dash voiding all warranty i had (i think). today when starting up my carputer, the xenarc led green light comes on, but doesn't show anything in the lcd pannel.
after troubleshooting it and spending an hour w/ my dash in pieces, nothing has changed. whenever the xenarc gets power, the led goes on and won't turn off. it doesn't blink, it's just always on and shows a black screen. the letters telling me what hz and resolution don't even come on.
any help? i double and tripple checked all the wiring in the back. when the issue first happend the ribbon belt had fallen off, but i put it back in and this still happens. this happens even if nothing is plugged in but the power...
help please. or tell me the right words to search cause i cna't find this and xenarc support isn't open on sundays...
Cerztrueheart is offline   Reply With Quote
Advertisement Sponsored links
Old 11-06-2006, 08:12 PM   #2
just called xenarc - said that it was probably my control board and i could send it in w/ a check for $115 and get it fixed. i might end up driving over there being that it's kinda attached to my double din dash insert.
said that they used to have a problem similar to this in which the F1 fuse would blow - looks like i get to go find a multimeter for a little fun
anyone have any other ideas of what it could be? or is there a cheaper way to fix this?
Old 11-06-2006, 09:42 PM   #3
digitalww's Avatar
digitalww is on a distinguished road
Hopefully I can save you some time here - Make sure that you plugged in your touch screen controller correctly. Here is a pic showing it plugged in correctly http://www.mp3car.com/vbulletin/atta...1&d=1162867189
4 wire connector should be aligned to the right of the touch controller connector.
Armen
http://www.digitalww.com
digitalww is offline   Reply With Quote
Old 11-07-2006, 12:45 AM   #4
@digitalwww
thanks for the input, unfortunatly those wires are connected and in the right spot.
Old 11-07-2006, 12:48 AM   #5
digitalww's Avatar
what if you unplug the touch controller completely, does it still behave the same?
@digitalwww
Old 11-29-2006, 05:49 PM   #6
same happens. can anyone tell me where i can get a touch controller? or do i just need to send it back to xenarc and hope they can fix it while it's out of warranty?
Old 11-29-2006, 06:04 PM   #7
digitalww's Avatar
On some of these I noticed that the main chip (big one in the middle of the board) is not soldered properly and some of the legs are not touching the PCB. You might not have this but take a look. You can slightly bend the PCB away from the chip and look at all the legs on all 4 sides. You will need a good eye.
Armen
Old 12-03-2006, 02:15 PM   #8
fiveslo's Avatar
fiveslo is on a distinguished road
I have a similar problem, however not so grave... anyways does or can anyone give any advice on how to reset the touchscreen to factory default? The reason I ask is my Xenarc 1040TS, powers up and displays correctly, however the touchscreen portion of it is acting completely haywire! I am running Streetdeck software as the front end, however have lost all control of the touchscreen! I can't get into the touchscreen calibration software since I've told Streetdeck to startup and shutdown WinXP automatically... Help..How do I reset the touchscreen????
fiveslo is offline   Reply With Quote
Old 03-06-2007, 07:57 PM   #9
aite, back from my long departure and tired of using my ipod as my car stereo. called xenarc and getting a RMA faxed back right now.
i'll keep this post updated with progress incase anyone else has a problem.
Xenarc 700TSV, Xm Direct, etc for sale Zinjamaster Classified Archive 7 10-02-2006 08:57 AM
Xenarc 700TSV 7'' touch screen krazymarine Classified Archive 3 09-20-2006 11:55 PM
Pandora w/ Xenarc 700TSV and Barrel Connector froalskiner General Hardware Discussion 7 07-20-2006 03:39 AM
Does Xenarc 700TSV & Xenarc MP-SC1 allow 800 x 480? xga LCD/Display 7 11-09-2004 03:33 AM
FS: Xenarc 700TSV touch UXGA capable cproaudio Classified Archive 16 01-20-2003 07:38 AM
