So now that I've finished fabrication of all the pieces necessary for a screen to be installed in my dash, I've been homing in on what to get. I originally was headed after the 6.5" VGA from EarthLCD (which had the outline drawings handy, so is thus what I designed from), but happened across GNET's webpage where apparently they are offering 7" Widescreen VGA displays.
http://www.gnetcanada.com/carlcds/pr...num=GNET_70VGA
You heard that correct, right down to the 15-pin VGA connector. They also have available a touchscreen version, with apparently the touchscreen is built in to the case. However, they're outta stock for the next month - and the display is only 200 nits which causes me some concern.
When I asked about what brand the LCD module is exactly, they weren't sure but had guessed Panasonic. Having said that, I found this display.
http://www.tmdisplay.com/tm_dsp/pana.../e-edtcb18.pdf
Sweet, 400 nits, and a 120 degree viewing angle! maximum resolution of 800x480. Perfect. Doesn't appear to be the same module as the one carried by GNET however.
Now the problem is, where to find this brighter module. Anyone come across these modules, or know of a supplier who handles Panasonic/Matsu****a LCD's? It seems these displays are only available overseas. I've seen some used ones for sell on LCD bulk buyer/seller websites, going at $150 a pop, but other then that have only found this obscure taiwanese website carrying a display that uses this particular module.
http://www.awst.com.tw/hardware-a.htm
It's the LAV-701
Just curious to see if anyone might have seen something like this before, or better yet, have any expierence with the model offered by GNET.
I'm trying to avoid calling Panasonic directly 'cause I know I'm gonna be rerouted half-way around the planet in my quest for that brighter display.
And besides, waiting a whole month.. UGH! I dunno, maybe i could handle it if really necessary.
Hell, even finding out what particular module is in that GNET display would be sweet. It's probably made by somebody obscure like AND or something.
AND, to add onto that.. Who here's uses a resistive touch screen and is it a pain in the ***? I can' help but wish for a capacitive, or acoustic but umm, 6.5" and 7" with a 16:9 aspect ratio are not exactly standard industry sizes.
Thanks in advance for the help guys!
