Old 11-21-2006, 12:50 AM   #1
garto is an unknown quantity at this point
Reverse Polarity, Xenarc
Okay so I've fallen victim to stupidity and I incorrectly hooked up my power to my Xenarc. I reversed the polarity. It is fried so I did a search so my question is, is there anyway to easily fix it besides buy a new board? I ask since the last post I found was in the beginning of the year so I wasn't sure if someone figured it out. If not do I just replace the controller board?
Thanks,
Chris
garto is offline   Reply With Quote
Old 11-21-2006, 01:04 AM   #2
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
it depends what you fried. More than likely a new controller board. Probably jsut as easy to buy a whole new unit.
Old 11-21-2006, 07:13 PM   #3
Crap, well I sent digitalww an email asking about what I need to replace. Hopefully they get back to me. Does anyone know the turn around time of xenarc on repairs? I know Armen is usually about a month.
Chris
Old 11-21-2006, 08:19 PM   #4
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
likely you fried at least the power circuit in the main board. It kind of sucks they don't spend the extra few cents to put a freaking diode to protect the board. I am pretty sure you can buy just the board on the net , for almost the whole unit price though.
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 11-21-2006, 08:30 PM   #5
Raw Wave
shotgunefx's Avatar
shotgunefx is on a distinguished road
WTF? Unbelievable that they skimp on the diode, especially when commonly wired pluglessly into vehicles.
shotgunefx is offline   Reply With Quote
Old 11-22-2006, 12:03 AM   #6
So has anyone dealt with the support center at Xenarc. My screen had been molded into a small dash piece and the buttons relocated so I hope I get it back the same way I send it in if I decide to go that route.
Old 11-22-2006, 12:06 AM   #7
2k1Toaster's Avatar
Somehow I think once you remove the "warranty void" sticker, and slap it into your dash, Xenarc has no responsability...
Old 11-22-2006, 12:27 AM   #8
Well I was assuming I was going to have to pay for it, I was just wondering if it was worth the hassle. Also what are the signs of a fried board? I plug it into the power correctly (after i plugged it in incorrectly) and the LED doesnt even light up, no buttons work. I did a voltage check and it said 11.7 v so I figured it was close enough. Anyone have a clue? I checked the voltage on the board across a few resistors as well and it says 11.7 v as well so I feel as if the board is definitely getting power.
Does this mean I blew everything if the led doesnt even light? Or is 11.7 v not enough to start the screen?
Chris
Old 11-22-2006, 01:12 AM   #9
Raw Wave
shotgunefx's Avatar
Chris
Maybe a transistor or cap? Leds are diodes so not likely to actually break from reversing the power.
Old 11-22-2006, 03:43 PM   #10
Well I started checking components on my board with a multimeter. I found that the first resistor is dead. However I'm not sure if I'm checking the capacitors the correct way, my multimeter says that all of them (15 or so) are not working. Is that even possible? the two large transistors however are fine, i'm going to try and replace the resistor to see if it helps. I'll keep you guys updated.
Old 11-22-2006, 04:28 PM   #11
Raw Wave
shotgunefx's Avatar
Weird, does it looked burned out? resistors don't have polarity so I'd be suprised if it got fried. dunno
Old 11-22-2006, 09:25 PM   #12
Okay well I replaced the resistor to realize that the next cap was destroyed. But that makes sense since its the second component inline. The transistor happened to be fine however. So hopefully this will be the last component needing to be replaced.
Old 12-01-2006, 05:32 AM   #13
gthing is an unknown quantity at this point
how did it go? I just did the same thing to my lilliput. F#$@ ME!
gthing is offline   Reply With Quote
Old 12-01-2006, 04:22 PM   #14
I replaced a few more caps, but it didn't do anything. So I got an rma number and I'm going to send it in for repairs.
Sorry I completely forgot about this thread as I've been trying not to think about it. UGHHHH it makes me mad that they wouldn't throw in a few diodes to protect the circuit.
Chris
Old 12-01-2006, 04:35 PM   #15
Raw Wave
shotgunefx's Avatar
Chris
Future reference for others, probably a good idea to use two different connectors, spade on the ground side, plug on the + side. Or even a blade and a barrel so you can't make that mistake.
Xenarc 700TSV N-tip Polarity Question Meta LCD/Display 3 04-17-2006 12:10 AM
reverse cam on xenarc video2 kuo General Hardware Discussion 2 05-29-2005 01:33 AM
reverse polarity nsmoller General Hardware Discussion 12 05-24-2005 02:30 PM
Another fried Xenarc - reversed polarity JC-S60 LCD/Display 1 08-22-2004 05:43 PM
what it the polarity for the xenarc power cord? G35Pimp LCD/Display 3 02-02-2004 06:42 PM
