Old 11-24-2006, 06:14 PM   #1
kireol's Avatar
kireol is an unknown quantity at this point
Xenarc 700 TSV randomly starting up with screen shifted
Sometimes, and I can't figure out a ryme or reason why, my xenarc 700 tsv will start up with windows shifted halfway across the screen.
So to fix this I have to go to auto detect and then it re-centers.
This is a brand new xenarc that I purchased from mp3car.
I have a home-brew PC powered off of a DSATX.
kireol is offline   Reply With Quote
Old 11-25-2006, 01:16 PM   #2
kireol's Avatar
has anyone heard of this or know how to fix or is this normal for a xenarc?
Old 11-25-2006, 01:48 PM   #3
Cheekz185 will become famous soon enough
right click on the desktop go to properties..... Click on the settings tab...then click advanced then go to the monitor tab....what is the screens refresh rate?? I have the xenarc 700 tsv and the refresh rate is 60hz..If it is on 60 try changing it..... But if its not on 60 put it on 60 and tell me what happens!
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
Cheekz185 is offline   Reply With Quote
Old 11-26-2006, 02:12 PM   #4
techy101's Avatar
techy101 is on a distinguished road
I have the same problem now and then. I have a power switch installed inline with the relay that I have setup to turn that screen on and off, so I just turn it on and off a bunch of times until it goes back to normal.
Also, you can auto-calibrate and it should fix the problem. I don't really have access to the buttons, so thats why I use the power cycle method.
Hope this helps
techy101 is offline   Reply With Quote
Old 11-27-2006, 06:11 PM   #5
PhilMayfield is an unknown quantity at this point
I have the same problem sometimes. One thing that seems to be working is that I have the desktop run at 800x600, but in RR config I have it switch to 800x480. So far so good with that setup.
PhilMayfield is offline   Reply With Quote
Old 11-27-2006, 06:24 PM   #6
Taxi49's Avatar
Taxi49 is on a distinguished road
Post
i have the same problem with my screen
change the refresh rate seem to fix the problem
if not you can try to plug the screen onto another computer
and see how it goes
~__o_\___
=-O----O-'
www.polares.com.au
www.itx.co.nz/index.php
Taxi49 is offline   Reply With Quote
Starting up lilliput screen without button PCB? Indust General Hardware Discussion 3 03-02-2006 10:10 PM
FS: 8" Xenarc VGA LCD Touch Screen Fatigue Classified Archive 5 09-12-2005 08:42 AM
8" Xenarc VGA Touch Screen LCD - $325 shipped digitalww Classified Archive 7 09-08-2005 11:15 PM
XENARC 700 TSV Remote Control kbreeden LCD/Display 0 08-08-2005 10:18 AM
FS: Xenarc 5m 700 series cable - NIB $35 gadget Classified Archive 2 05-11-2005 04:32 PM
