The MP3car.com Store
Thread Tools Display Modes
Old 12-01-2006, 12:04 PM   #1
Vehicle: mk2 vw golf 1.6
My Photos: (0)
toutchscreen playing up. keeps going blank!! **HELP**
hey guys, im having some trouble with my 7" monitor. it doesnt have a brand name on it or in the manual. but it does say it model number, which is: XDXP070Z
now, when i first got it i tried it on one pc. and it was showing the screen but the after about 2 seconds it would go blank. the power was still on, and i could even go through the video inputs back to VGA, and it would show the screen.. but only for a couple of seconds, then go blank.
SO
i took it to another pc in the house with the same car battery. and plugged it in and it worked FINE.
i then tried it again but on my own pc, and again.. it worked fine.
but since then it has been back in its box. but now i have the rest of my car pc. i got it out and tested it. and the bloody thing has gone back to displaying the screen for a couple of seconds and going blank again. the same as when i first tried it.
but i have tried it with the two pc's that it worked with before, but no joy. still the same thing.
anyone know why this might be happening? or what i could try?
Thanks!
iamlone is offline   Reply With Quote
Sponsored Links
Old 12-01-2006, 12:27 PM   #2
Calm
Down
Or
Get
A
2
Week
Vacation
-Love
The
Forum
Policeman
Wiredwrx's CarPC Specs
Wiredwrx's Avatar
My Photos: (0)
Sounds like perhaps a loose cable or connection. If you can;t find anything, it is possible that the controller card has gone bad. Check all connections, make sure you have enough voltage and amperage AT ALL TIMES during operation, and open the unit and make sure everything is seated correctly.
Michael
...I love the French language...especially to curse with...Nom de Dieu de putain de bordel de merde de saloperies de connards d'enculés de ta mère. You see, it's like wiping your *** with silk, I love it. www.yellinlawoffice.com
Wiredwrx is offline   Reply With Quote
Old 12-01-2006, 12:51 PM   #3
My Photos: (0)
well i know the VGA cable is all there, because when i dissconnect it after its gone blank, it flashes DISCONNECT for a couple of seconds then goes blank!!! this is really annoying..
Old 12-01-2006, 02:45 PM   #4
My Photos: (0)
is it possible tha its going to the sleep mode(power save) for some reason ?
if you can find some way to reset the settings, it would be worth to try. (generally it is some key combination press & hold at power up)
0-0-7 is offline   Reply With Quote
Old 12-01-2006, 04:22 PM   #5
My Photos: (0)
hmm, i'll have a play. im most confused though because it worked after just moving the stuff to the second computer i tried it on.
Old 12-02-2006, 04:22 AM   #6
My Photos: (0)
ok.... wtf. i just tried it again and its now working.. i have done NOTHING different. soooo confused!
Old 12-02-2006, 06:18 AM   #7
My Photos: (0)
cuold it be that theres a battery inside that needs to charge before it can switch on properly, because that would seem to tie in with whats happening at the mo.
Old 12-02-2006, 09:36 AM   #8
Redian's CarPC Specs
Redian's Avatar
Vehicle: 2004 Subaru Impreza WRX
My Photos: (0)
get a new cable maybe? it could just be soethign as simple as that,
if its a lilliput, i have a spare cable i can send to you for a few bucks
or you could have just not connected the wire well, thus causing the monitor to connect and disconnect to the vga signal... and when you moved it around, it could have just put it in a place where the connections are always there...
but without being there, i could never be 100% sure
2004 Subaru Impreza WRX CarPC Install
Install: 90%
"When you go 0-60 in 4.5 seconds, you don't need a made up character called fast. Thats what makes a Subaru, a Subaru."
Redian is offline   Reply With Quote
Old 12-02-2006, 09:54 AM   #9
My Photos: (0)
no, im 100% sure all the cables are fine. im pritty sure now that all it is.. is that you have to have it connected up to the battery about 2 mins before turning it on. must be a capasitor or something
Old 12-03-2006, 09:32 AM   #10
My Photos: (0)
Smile
I've got same problem like you, but my monitor diff model of your
it make me crazy a week.
So i'am just do this:
- wiring GROUND rail directly from car battary (- connecter) to one of black cable output from M2-ATX
For me i'am do only this all of my monitor problem was fixed.
Hope this can guide you for fix your monitor problem.
Sorry for my poor Eng.
iamE38 is offline   Reply With Quote
Sponsored Links
Old 12-03-2006, 04:58 PM   #11
My Photos: (0)
all i press in this video is the VGA button on the R/C after it first goes blank.
Old 12-04-2006, 10:28 AM   #12
My Photos: (0)
ok, something intresting....
with it all plugged in, but the pc off. i turned the screen on, and it showed a blank screen then blacked out again. i then turned on the pc, and the screen showed the boot up screen for a couple of secs then blanked again. once it got to the windows loading bar thing, it came on for 2 secs then went again. and the same happend when it got onto windows... it showed for 2 secs then went blank.
i dont know if this could help with trouble shooting... if anyone has any ideas, please let me know.
but i dont want to open it up as it might void the years warrenty i have. if i can even get the supplierto respond..
Old 12-14-2006, 06:03 PM   #13
azizi's CarPC Specs
Vehicle: VW Mk3 GTI Edition
My Photos: (0)
http://xdx.manufacturer.globalsource...GetProduct.htm
there is a brand and home page for your lcd
i check it for this number XDXP070Z
azizi is offline   Reply With Quote
Old 01-23-2007, 02:20 PM   #14
RavageiWISE's Avatar
Vehicle: 2004/Nissan/350Z
My Photos: (0)
Did you get it fixed?
I was looking at the same model. How do you like it for quality and did you get it fixed?
RavageiWISE is offline   Reply With Quote
Old 01-23-2007, 09:35 PM   #15
My Photos: (0)
I just had this same issue with an in-dash I purchased. I just sent it back for another. Would be nice if we could get to the bottom of this though.
MantisX
MantisX is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Lilliput 619 Blank Sreen?? HELP Shmeker LCD/Display 11 11-28-2007 10:54 PM
Playing DVDs dovla Road Runner 6 05-23-2006 06:12 PM
xm and mp3 playing at the same time bswift Mobile Impact 12 01-15-2006 04:19 PM
Voice Recognition Whilst Playing Music? konnichiwa Software & Software Development 7 09-30-2005 01:54 PM
Having trouble playing video Keebortz General Hardware Discussion 2 07-27-2005 07:18 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
