The MP3car.com Store
Thread Tools Display Modes
Old 12-12-2006, 01:36 AM   #1
My Photos: (0)
auto on for EBY701 lilliput...
people says it's programmable and the code that is posted to get to the setup menu 588998 doesn't work on this model seemingly. Is there a way people have found out without soldering to get the auto on to work? I've been on the forums for about 6 hrs now, and my eyes hurt to search more.
thanks in advance
Cars:
2001 Lexus es300 carpc Complete!Lexus es300 thread
CarPC: Hp laptop, Lilliput 7'' ts, ig3, bluedevil skin, hauppage tv tuner, bu-353, griffin powermate, backup camera, ps2, headrest monitors, nightvision camera.
2006 Lexus es330 next project.
spiike is offline   Reply With Quote
Sponsored Links
Old 12-12-2006, 02:43 AM   #2
NiSlo's CarPC Specs
NiSlo's Avatar
Vehicle: 06 Impreza Hatch
My Photos: (16)
I have the 701, and it worked perfectly for me first go. I didn't press slowly or anything. Just picked up the remote, punched in the code and off I went.
Here's my post http://www.mp3car.com/vbulletin/show...8&postcount=71
It took alot of people a few go's to get it.
I installed my carpc into my pet Kangaroo, mate.
NiSlo is offline   Reply With Quote
Old 12-12-2006, 11:24 AM   #3
My Photos: (0)
that's so odd. I literally spent 3 hours trying to get the thing to work. Knowing that you have the same one and got it to work is encouraging. Do you have to do it when the blue lights are off as someone had previously posted? I tried fast, slow, counting 2 secs between and 3 secs between, and none of them worked. Did you have to press menu to get the setup screen after you put the numbers in?
(sorry for bombardment of questions, just frustrating after so many hours to get this work.. even tried up up down down left right left right.. haha)
Cars:
Old 12-12-2006, 04:12 PM   #4
NiSlo's CarPC Specs
NiSlo's Avatar
My Photos: (16)
What I did, was connected the power and turned it on. That brought it to standby mode, where only the blue power button is illuminated IIRC. I pressed the power button and the screen turned on. Put in the code with the remote which brought up the On Screen Display of --------- . I entered the second code as pe rmy post above, pressed '5' (any button works) and then turned it off. I then disconnected and reconnected the power and now it turns on automatically.
Do you have the vga source connected, or are you just plugging the power in and trying it that way. I had the vga cable connected. When I entered the program code it had a VGA source from my computer
Old 12-12-2006, 05:15 PM   #5
My Photos: (0)
vga source is connected. I hope i'm not wearing out hte 5,8,9 buttons on the remote cause i'm doing this so much.
I've tried every single combination of ways to do it.
1. plug in put in code
2. plug in press power put in code with blue buttons on
3. plug in press power wait for blue buttons to go off and put in code
4. plug in press power wait for blue buttons to go off and put in code and press menu
5. 2 sec intervals between number
6. 3 sec intervals between numbers
7. entered 588998 really fast
I did this after unplugging each time at least 300 times.
Nothing is working. LCD does look really nice though.
Cars:
Old 12-12-2006, 05:39 PM   #6
My Photos: (0)
OK OK I GOT IT.
I dont know what compelled me to do this but I removed the battery from the remote incase the remote has some kind of memory that stores the numbers. I can get it every time now as long as I remove the battery from the remote and unplug the monitor. Otherwise it wont work.
So..
1. remove power
2. remove battery from remote
3. put battery back in and power on the unit
4. wait 3 secs for unit to power on (blue lights still on) and steadily put in the numbers not slowly but pretty quick.
5. then this
I hope this little thing with the battery can help those that never got the status screen or is thinking of soldering. Mine auto-on's every time now and i can get the status screen every time now with this procedure =) Thanks Nislo for your posts. I was giving up until I saw you had the same unit and got it to work. + reputation points if the forum has it.
Cars:
Old 12-12-2006, 06:51 PM   #7
NiSlo's CarPC Specs
NiSlo's Avatar
My Photos: (16)
Good to see you got it working! How odd that you need to remove the batery everytime though...
Hooray for tempramental electrical equipment
Old 12-25-2006, 10:58 PM   #8
My Photos: (0)
I just got my lilliput 7 with a serial of EBY701832810157 and when I put in the code 599889, it brings up a window with the languages on it only. It doesn't give me the OSD with the dashes on it so I can put in the 2nd code. Any ideas?
tmproff is offline   Reply With Quote
Old 12-25-2006, 11:12 PM   #9
My Photos: (0)
AHAH!!!! Ok, I figured it out. After you put in the 588998, you have to push the menu button on the monitor itself! After that it brings up a new menu screen with lots of options (I dont have my camera, but I'll try to snap a pic of the menu tomorrow). There is an option for power mode and I switched it from 0 to 1, and I also turned off the 2 sound options. After I hit the menu button again, I turned off my PC and turned it back on, and the lilliput now auto powers on!!
Thanks for everyone's help on this.
Old 12-31-2006, 05:32 PM   #10
guizai's CarPC Specs
Vehicle: 89 BMW 325iT
My Photos: (0)
Followd your steps exactly and got the same menu. Pressed menu on the screen and got the second green screen with the following options:
PC ----- ON
VIDEO 1 ----- ON
VIDEO 2 ----- ON
SVIDEO ----- OFF
TV ----- OFF
POWER MODE ----- 2
BRCK CAR ----- OFF
VGA VOL ----- ON
VIDEO VOL ----- ON
DEF SOURCE SWITCH ----- OFF
DEF SOURCE ----- PC
I'm not sure what BRCK CAR means.
guizai is offline   Reply With Quote
Sponsored Links
Old 02-25-2007, 11:13 PM   #11
My Photos: (0)
it works
thanks guys for all your import i got it to work just fine a few things i noticed while working whit it is that the blue button lights need to be off before you press 588998 then once you press in the number on the remote press the menu button on the screen itself not the remote. then use the left and right arrows next to the menu button on the screen to navigate up and down then use the volume buttons on the screen to change the values after you get done press menu again to exit and your done no soldering what so ever
exdox77 is offline   Reply With Quote
Old 03-07-2008, 09:25 AM   #12
HiJackZX1's CarPC Specs
HiJackZX1's Avatar
Vehicle: 03 Dodge Durango SLT
My Photos: (231)
Nislo, u you seem experienced with the EBY701. Is there a auto switch feature, for like rear view cameras?
PLANNING [50%]
CAR PC ITEMS [75%]
INSTALL OF PC [80%]
INTERIOR MODS [35%]
BUDGET [380%]
HiJackZX1 Work Log
HiJackZX1 is offline   Reply With Quote
Old 03-11-2008, 04:30 AM   #13
HiJackZX1's Avatar
My Photos: (231)
This screen does not have auto switch, but I have made a mod to do it. Someone told me the BRCk has something to do with when the car is moving it turns off the screen so the driver cannot view it...
PLANNING [50%]
CAR PC ITEMS [75%]
INSTALL OF PC [80%]
INTERIOR MODS [35%]
BUDGET [380%]
HiJackZX1 Work Log
Old 04-12-2008, 12:54 PM   #14
My Photos: (0)
hey fellas, I in the process of configuring the auto on for my eby701 and am having some trouble. I manage to get to the screen where the options for power mode and set it to 1 but after I cut the power from my ignition and reboot the pc, the screen does not auto power. I check the option power mode again and notice it got reset back to 0. Why and how...?
Here is my steps to get to the option:
1. after all the powering off and on with the battery and unit itself, boot it up and enter 588997
2. I get a language screen, on the language screen I press the menu button on the unit itself not the remote to get to the power mode screen.
3. Change power mode from 0 to 1 and press menu on remote.
also after all this is done i repeat the steps to check if the option stayed and it did. But when I turned off the ignition and turned it back on the unit did not auto power. I went back to check the option and it reset. What am I doing wrong. Thanks in advance.
hongchu is offline   Reply With Quote
Old 04-14-2008, 04:19 PM   #15
My Photos: (0)
Just to let you all know, worked on my eby701 - Although I didnt get the ------- screen, I did get a language select screen, pressing the menu button on the unit got me to the right screen though,
Power setting 2 is auto power on btw works a treat
leighbee is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Lilliput 629 Auto detect and switch hpric LCD/Display 2 03-29-2006 10:10 AM
Lilliput auto - switching Video HagOO LCD/Display 0 11-05-2005 03:21 PM
Idea for auto on for lilliput Dave_Perth LCD/Display 1 04-10-2005 05:28 AM
lilliput auto switch video p4intel General Hardware Discussion 0 04-08-2005 10:34 AM
Auto turnon Lilliput? slboytoy LCD/Display 64 08-25-2004 06:29 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
