The MP3car.com Store
Thread Tools Display Modes
Old 12-13-2006, 10:36 PM   #1
My Photos: (0)
Question about Lilliput screen
Hey there,
I just got done installing a lilliput 7in touch screen to a EVO mobile workstation which is powered by a 350 watt unsure of the Amps inverter. Now when I power the screen up, the screen gets lines through it. Exact same as when you are watching TV and see a computer screen with lines running throught it. The lines are slow moving and annoying. Now. I was powering the monitor with the same 12 volt wire that is running to the inverter. After I noticed the lines. I took and made a new 12v wire for the monitor from the battery. Now, the ground is still hooked up to the one that is running to the inverter. The inverter is hooked directly to the battery. Now, I'm wondering as I think about it, should I make a new ground for the monitor also?? Is there a problem with the inverter not pushing out enough power for the video card (just an thought). I also heard about breaking the ground prong off of the plug on the inverter.
The serial (VGA) cable running from the lilliput to the computer doesn't have a filter on it. (Again another thought). Doesn't change if the car is running either. I hooked up an extension cord to the computer to test it and it works fine with no lines going through the monitor.
What is causing my monitor to do this and what are some possible fixes? I was going to start the process of eliminaton, but for one that gets expensive and a pain in the ***.
Let me know,
Mike
mike_b49431 is offline   Reply With Quote
Sponsored Links
Old 12-14-2006, 09:59 AM   #2
My Photos: (0)
Daily Bump
Old 12-14-2006, 01:33 PM   #3
david69leonard's CarPC Specs
david69leonard's Avatar
Vehicle: 2003/mitsubishi/eclipse
My Photos: (13)
it kinda sounds like you do have a grounding issue, i think its the same as if you were hearing alternator noise through your speakers. I would try to ground it to a seperate grounding point other than your inverter. if that doesnt work then a ground loop isolator might work.
david69leonard is offline   Reply With Quote
Old 12-23-2006, 04:34 PM   #4
My Photos: (0)
Well. I upgraded the inverter from a 350watt to a 400 with 800 peak. It cleaned up the lines, but I can notice waves going through the screen and the screen is slighlty distorted which makes it hard to read. Should I still try a ground loop isolator thing?
Old 12-23-2006, 07:19 PM   #5
treetop777's CarPC Specs
treetop777's Avatar
Vehicle: 1981 Ford F-100
My Photos: (0)
is it calibrated?
treetop777 is offline   Reply With Quote
Old 12-24-2006, 07:19 AM   #6
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
Calibration has absolutely nothing to do with this problem. Calibration is only for the touchscreen.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 12-26-2006, 08:31 AM   #7
My Photos: (13)
sometimes my 19" monitor in the house has the same waves going through it when i have the resolution set too high, try setting it to a lower resolution.
Old 12-28-2006, 08:26 AM   #8
Vehicle: 1993 Lexus SC300
My Photos: (0)
Mine does the EXACT same thing. For some reason after some time it fixes itself(Like 30 minutes[I have it running in the house]) I'm pretty sure it have to do with refresh rates but I can't edit then yet
diablodemorte is offline   Reply With Quote
Sponsored Links
Trackbacks are Off
Lilliput screen flash lgbr LCD/Display 10 12-13-2005 11:15 AM
8" Lilliput question, extracting sound and screen rolls clean customs LCD/Display 5 06-30-2005 10:10 PM
7" Lilliput VGA Screen $200 Rundell Classified Archive 8 11-22-2004 07:04 PM
Starvision Lilliput And Pixelon All The Same Screen? MP3 MOBSTER LCD/Display 2 11-15-2004 03:16 PM
Lilliput Question patrol LCD/Display 6 12-28-2003 06:15 PM
Sponsored Links
Ad Management by RedTyger
