For your trunk mounted PC's, wow far are you extending your LCD's power?
Xenarc 700TSV
I've had to extend the power about another 5-6 ft. using 14 ga cables for the LCD to reach the molex connector on my PC.
I tested the setup, in-car, before running the actual wiring and it was working okay, I suppose.
However, ever since I mounted the LCD to the fabb'ed bezel, my TS has been acting up.
Symptoms:
Power LED on, but no image and no TS
Occasional white screen
I can hear the TS beeping, but still, with no image.
Powering down fully and cutting off power completely and waiting about 20 mins. cures it, until I fiddle w/ the installation of the screen and bang, I'm back to square one.
I've checked my wiring and all is good.
I've also noticed that the screen is not as bright as used to be under the same setting. Even in daytime, I used to be able to view it okay, but now, I can barely make it out. That was before I extended the LCD power cables.
In addition, I used the 14 ga cables to run power/ground straight from the battery to the PSU. Again, I tested this setup in-car and everything appeared to be working properly.
If anyone can help give me some insight as how to tackle this, I'd greatly appreciate it.
TIA!
nLite'd XP Pro / RR v09/10/2008 / Winamp v5.13
