Old 01-08-2007, 02:37 PM   #1
Sal R.'s Avatar
For your trunk mounted PC's, wow far are you extending your LCD's power?
Xenarc 700TSV
I've had to extend the power about another 5-6 ft. using 14 ga cables for the LCD to reach the molex connector on my PC.
I tested the setup, in-car, before running the actual wiring and it was working okay, I suppose.
However, ever since I mounted the LCD to the fabb'ed bezel, my TS has been acting up.
Symptoms:
Power LED on, but no image and no TS
Occasional white screen
I can hear the TS beeping, but still, with no image.
Powering down fully and cutting off power completely and waiting about 20 mins. cures it, until I fiddle w/ the installation of the screen and bang, I'm back to square one.
I've checked my wiring and all is good.
I've also noticed that the screen is not as bright as used to be under the same setting. Even in daytime, I used to be able to view it okay, but now, I can barely make it out. That was before I extended the LCD power cables.
In addition, I used the 14 ga cables to run power/ground straight from the battery to the PSU. Again, I tested this setup in-car and everything appeared to be working properly.
If anyone can help give me some insight as how to tackle this, I'd greatly appreciate it.
TIA!
nLite'd XP Pro / RR v09/10/2008 / Winamp v5.13
Sal R. is offline   Reply With Quote
Old 01-08-2007, 02:46 PM   #2
what screen do you have? if xenarc you need to check the internal ribbon cables they tend to move when fabricating. for the brightness it depends on how much current you supply, before installing in the car you probably used the external power supply which supplies 1 amp but with the computer psu it could be less..
hope this info helps
vxr666 is offline   Reply With Quote
Old 01-08-2007, 04:34 PM   #3
Sal R.'s Avatar
Ribbon cables are good. It was one of the first few things I checked after finding that in a search.
Powered down, waited another 30 mins. And it seems to be back to normal. Though still dimmer than I remember, but I suppose that's subjective.
I'm gonna undo the power wiring to see if that helps the brightness issue.
Old 01-08-2007, 05:05 PM   #4
JimmyFitz's Avatar
My PC is in the trunk with power tapped from molex through about 15 feet of 16 ga multiconductor to get to the Xenarc screen. Length probably isn't your problem.
2002 T-Bird, Via SP13000, Travla C158, M1-ATX, 1GB RAM, 120GB 2.5" drive, SlimSlot DVD-RW, XP, RR, Winamp, Xenarc 700TSV, HTC Touch PPC/Phone, BU-353 GPS/iG3, Elmscan OBDII, Griffin PowerMate, 2 Blaupunkt amps, Polk spkrs, 5 sec startup/S3 STR
~Jimmy
JimmyFitz is offline   Reply With Quote
Old 01-10-2007, 04:51 AM   #5
for the power try making a circuit with a 12V 1Amp voltage regulator LM7012 i think thats the one to use and use to capacitors for filtering and connect this to the car battery if the brightness is better just install it to a relay to the Acc of the car. Hope this helps and if you need help in the circuit just ask and i send a schematic.
Old 01-10-2007, 09:29 AM   #6
Sal R.'s Avatar
Update: My screen is dead. The TS works, but I no longer get the PC, AV1, AV2 source option, and the menu doesn't come up. Nothing at all comes up and the screen looks as if it is turned off
The power LED still lights up and powers on/off, but just no image. The screen was operating at a resolution 800x600 at 60-61 Hz.
Seeing that it's f-ed up anyway, I'm not so scared anymore of taking it apart.
Damn these things are sensitive pieces of equipment.
FAQ: Power Supplies Explained (Part 1) Bugbyte The FAQ Emporium 14 06-10-2007 07:45 AM
FS: ITPS shutdown controller and PW-70a MINI-ITX power supply hanzacra Classified Archive 4 08-07-2005 10:32 PM
power 2 LCD's from power supply MrHealer Power Supplies 0 06-07-2005 11:52 PM
DC-DC Car Power for Mac Mini MikeH MacCar 53 02-19-2005 12:13 PM
How can i get power in the trunk? helloman General Hardware Discussion 3 04-19-2001 08:34 PM
