Old 01-09-2007, 12:37 PM   #1
kish89 is an unknown quantity at this point
TM-868 touchscreen pinout
Hi to all
I have this LCD and cable for connecting it to PC is to short so i decided to make it longer
But there is a problem, because wires with VGA connector are melted with other color wires which are going to LCD.
I've cutted out that part were they are melted and dont know how to connect VGA connector color wires with other color wires which are going to LCD.
Please help me, it hink i need a pinout.
Thanks.
btw.sory for mine english
kish89 is offline   Reply With Quote
Old 01-10-2007, 07:17 AM   #2
can you please help me, its urgent
on the lcd side i have this wires for connecting the VGA connector green,blue,red,black smaller, black biger(fater ) , and brown-grey or somethin.
but dont know to which pins on VGA connector i need to connect this wires.
i always get no sync message on LCD.
oh yeah on tha vga connector side there are black,orange,green,red,yellow and brown-grey or somethin.
again lcd model is 8"tft touchsreen TM-868
thanks in advance
Old 09-23-2007, 02:40 PM   #3
dbtoutfit is an unknown quantity at this point
did you solve this problem or do you still need the pin out?
dbtoutfit is offline   Reply With Quote
Old 09-29-2007, 11:12 PM   #4
avengerdude27 is an unknown quantity at this point
i need it too so please
avengerdude27 is offline   Reply With Quote
Old 09-30-2007, 12:31 PM   #5
k let me draw one up..
Old 09-30-2007, 01:05 PM   #6
BTW you do have the monitor with one cord, on the end it has VGA, a red video, a yellow video, a white audio, a black power plug and a usb plug... correct?
do you need to know what each wire is for or what each group is for?
Thick Red wire = Red Video (wire is double layered, outside layer is common ground)
Thick Yellow wire = Yellow Video (same thing)
White wire = audio
Meduim red wire = Power
Solid black wire = Ground
All wires besides these above wires are USB wires.
2 are brown wires = dead they are not used at all
1 is a pink wire = it's hot so to speak but at the monitor it's not used either can cause issues (read below)
The set of wires in the very center of the bundle in the tin foil with plastic outside = vga.
Hope this is what you were needing to know.
If not let me know.
Few trouble shoot tips:
Monitor says "No Signal" after making sure that the video source is there.
Make sure the monitor is set to vga or Video 1 or 2, what ever your input is. I know it may sound dumb but I have seen so many people do this. Mostly from bumping it and no knowing.
When USB plugged in, monitor goes from showing picture or "no signal" to blank screen and red power light gets dim.
The cable bundle going into the plastic in the back of the monitor has heat shrink on the end of the black outside rubber skin and wire the wires come out of it to keep some wires in place. Problem is they never designed something to hold the wire in place. It comes from the screen mobo (motherboard) straight out the back. This heat shrink tends to get moved.
When this problem starts its the pink wire touching the naked ground wire.
At this point the heat shrink is more than likely loose enough to slide down just a bit. Pull the pink wire backwards so that it is resting on the very outside of the cable, cut any showing bare wire coming from the pink wire and slide the heat shrink back over it. Use a heat gun or lighter to work the heat shrink. If you do not bend the pink wire backwards so that it is point down to the adapter end of the cord and resting ( so to speak) on the outside of the main cable, when you go moving it all over again the plastic case is going to catch the heat shrink and work the pink wire right back into the ground.
Old 10-02-2007, 02:32 PM   #7
helpful but knowing what pin goes to what wire would be awesome too because i was just going to make up a new cable with the connectors and stuff i have here there was no salvaging it damn lab puppies
Old 10-02-2007, 02:53 PM   #8
from where to where do you need to know the pin out? All the way from the screen mobo?
Old 10-08-2007, 02:07 PM   #9
i need to know where each pin of the screens connector goes so i can make a new cable
Old 10-08-2007, 02:28 PM   #10
Ok, I will try to get that to you asap. I already have everything installed in my car and will have to uninstall a few things to get to that. I know how it sux needing something so simple yet know answers.
I will try to get the info to you very soon.
Old 10-08-2007, 02:45 PM   #11
thank you
Old 10-09-2007, 07:57 PM   #12
Heres the pin out.
Hope this helps,
Eric
Jackedupcustoms.com
tm 868 8 inch monitor and some other stuff sti robot Classified Archive 6 10-25-2006 11:53 AM
wtb ebay tm 868 touchscreen selmerguy Classified Archive 6 07-05-2006 05:30 PM
FS: 8" TM 868 recessed in 2000 Honda Accord (Ready to go) wu4607 Classified Archive 2 05-17-2006 01:32 AM
Pinout for tm 868 Baloo LCD/Display 4 11-29-2005 11:06 AM
tm 868 ebay monitor...touch issue tarpitblue LCD/Display 14 10-17-2005 02:20 AM
