Alpine 7" VGA Monitor w/ built-in Bluetooth - Retail $450 - Available in March
Specs:
• 7" WVGA Touch Screen Monitor
• 1.15 million pixels
• RGB 800x480, 16:9
• Built-in Bluetooth module
• Streaming Audio ready (requires Ai-NET to RCA)
• 2DIN mounting bracket for in-dash installation included
• 1 A/V input
• 1 A/V output
• Dedicated camera input with reverse sensor
• Provision for external Bluetooth microphone
Features (from Alpine):
Need to add a monitor to your system? New for 2007, the TME-M740BT is the ideal stand-alone monitor to fit your needs. This 7-inch WVGA monitor boasts 1.15 million pixels for excellent image quality and viewing angles with a 16:9 image aspect ratio. It’s also equipped with a touch screen display for convenience. With built-in Bluetooth compatibility, you can get on-screen touch control of your Bluetooth enabled cell phone.
Easy Phone Access with Bluetooth™
The TME-M740BT features a built-in Bluetooth module and microphone. With the Bluetooth function enabled, you can have access to received calls, dialed numbers, and missed call histories right from the monitor. Your phone book is also displayed through the monitor and you can dial using the 12-key direct number input, or via on-screen speed dial and quick call button.
Streaming audio from A2DP-enabled mobile phones, such as Motorola’s music service, can be accessed through the TME-M740BT’s Bluetooth connection. You can also get access to all your MP3 music stored on your phone. Basic music playback functions from compatible pones, such as Play/Pause, and Track Forward/Backward, can be controlled from the TME-M740BT’s touch screen.
Total Control Over The VehicleHub Pro System
If you want an on-screen display to compliment your VehicleHub Pro, VPA-B222, set-up, you can add the TME-M740BT. The VPA-B222 is a the control hub for expansion – iPod®, 5.1 surround sound, Satellite Radio, HD Radio, navigation, the possibilities are endless, without even having to change out your dash. With such a wide array of functionality, it’s only fitting to get the highest resolution touch screen control for your ultimate system with the TME-M740BT.
Fit for the Navigation System
Add Alpine’s premier navigation without changing out your factory dash – you can simply mount the TME-M740BT, connect to the NVE-N872A and navigation is at your command. Likewise, if you own an Alpine Blackbird, you can have it output to the TME-M740BT for a larger, more convenient display. Get touch control and remote control of your navi. The TME-M740BT comes equipped with a built-in speaker so you will get full voice guidance from your navigation unit, turn-by-turn.
