Old 01-10-2007, 04:13 AM   #1
jschulze is on a distinguished road
Need help identifying backlight inverter component Dynamix 816
Hi,
Long story short I broke a component on the backlight of my dynamix 816 (same as tview and provision). Since I though it was shot already, I started poking around with my multimeter probe and low and behold the backlight lit up when I poked the broken component, so I jumped the part with some solder and the screen worked fine. I'm guessing the part I broke has some function and the inverter probably won't last too long with out it. I'd like to just replace the component instead of the whole inverter, so here's a picture of the part. If there's any kind hearted individual out there that could tell me what this little sucker used to be I'd be greatly appreciative.
The inveter is a Hitachi PH-BLC88.
Here's some pics.
jschulze is offline   Reply With Quote
Old 01-11-2007, 09:47 AM   #2
decanus is an unknown quantity at this point
Did it have a number on like the component's surrounding it. It's impossible to tell without seeing the actual component that came off but it is more than likely a surface mounted resistor.
If you can find and take a picture of the original component we can go from there.
Regards Dean
decanus is offline   Reply With Quote
Old 01-13-2007, 02:25 AM   #3
I can't take a picture of the orginal component, because I broke it into a bunch of little tiny pieces. I was hoping someone might have the same screen or inverter and could look on theirs. I might just try to get a hold of dynamix and see if one of there tech support guys could help me.
Thanks,
Jordan
relay, inverter, fuse problems cheesyhoward General Hardware Discussion 6 06-22-2004 04:05 PM
Backlight Inverter How? What? Where? Squeeky LCD/Display 3 11-20-2001 03:25 AM
LCD Backlight inverter Question accord LCD/Display 1 08-15-2001 03:44 PM
Do i need backlight inverter for Sharp 6" LCD ? helloman LCD/Display 4 04-13-2001 10:51 AM
odd inverter behavior jshrieve General Hardware Discussion 30 04-10-2001 05:53 AM
