Old 01-10-2007, 08:49 PM   #1
stanford1621 is an unknown quantity at this point
what would drawbacks be to this monitor
http://cgi.ebay.com/14-inch-OVERHEAD...QQcmdZViewItem
My plan would be to disassemble the housing and fiberglass this monitor into the dash, it has a remote to control power etc. should be ready to run on 12v, what kind of inputs do these usually have? and would the resolution be acceptable for a main monitor in a car pc?
Or this one I didn't want to go touchscreen but it looks like a complete kit and the price quite low
http://cgi.ebay.com/NEC-12-LCD-Displ...QQcmdZViewItem
stanford1621 is offline   Reply With Quote
Old 01-10-2007, 09:59 PM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Resolution appears to be fine, but there's no VGA input. That will reduce teh quality of your display significantly. It would also require you to have hardware that allowsd you to output video signal to a composite video port.
The second link would require additional parts to get operational with a VGA signal, and would make the low cost of teh bare screen not worth it in my opinion.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 01-10-2007, 10:33 PM   #3
Banned
Motorcity's Avatar
Motorcity is on a distinguished road
huh? come again??
a 70.00 lcd controller and you have a 12.1" ELO/NEC s.a.w. setup. Not worth it???
Ok, maybe I missed the boat, but where else are you going to build or buy that quality for less than 200.00???
Have you seen the specs on that lcd panel?
btw, that seller is a great guy. I have been buying from him for 6+ years. Always has top shelf stuff cheap.
Motorcity is offline   Reply With Quote
Old 01-10-2007, 11:01 PM   #4
I would have thought that the controller would be a lot more than that.
I stand corrected. That's a damn fine deal, then.
Add a touchscreen overlay, if needed and that's some right fine screenage.
Old 01-20-2007, 10:33 AM   #5
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
If these are going to be used to show the XP desktop and used for the computer...I'd look elsewhere.
If it's going to be used solely for video playback, it should be fine.
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Help needed RGBS monitor - needs VGA input Zductive LCD/Display 15 10-13-2007 05:50 PM
Headrest Monitor or Dash Monitor BIzFlawless Classified Archive 3 01-28-2006 04:16 AM
Questions on In-Dash LCD Monitor Hook Up for a Beginner PapaPrem Newbie 1 04-10-2005 06:24 PM
Questions on In-Dash LCD Monitor Hook Up for a Beginner PapaPrem Newbie 1 03-23-2005 12:41 PM
Running windows with no monitor? BLACKOUT General Hardware Discussion 14 03-14-2001 11:56 AM
