Old 01-18-2007, 11:39 PM   #1
Lankers_B is an unknown quantity at this point
Z4-e85 display hack...
What does it take for someone to use a Z4 (e85) display as a carputer monitor? BTW, I am looking to do this in something other than a BMW...
Lankers_B is offline   Reply With Quote
Old 01-19-2007, 11:33 AM   #2
legacy05gt's Avatar
legacy05gt is on a distinguished road
Join this group:
http://autos.groups.yahoo.com/group/...guid=116341306
And read this thread:
http://www.mp3car.com/vbulletin/worklogs/87541-bmw-540i-project-part-2-a.html
You need to "hack the I-Bus". Also, use the search button. Took me 30 seconds to find this info.
Progress:99% not 100% because theres always something to do...
Centrafuse on XP (lited)
EN15000
120GB 2.5" SATA HD
1GB DDR2 Ram
M2-ATX PS
Slot-Load DVD
BU-353 GPS w/Mappoint 2k6
DWW-700M
legacy05gt is offline   Reply With Quote
Old 01-19-2007, 02:51 PM   #3
Ya know, I did use the search button and I did find that thread and I did sign up for that group.
But ya know... I read that thread and I have no idea on how to "send packets". Powerstrip - not sure where to start there. And, I do have that question out on the yahoo group - no answer there (although I am hopeful).
I even went out to DarthTater's site and read it through - no help there. So I sent him an email, no answer yet.
And instead of hijacking his thread, I figure I'd start another.
Been searching for a few weeks on and off, here and on the web - still no answers. And I do appreciate your "30 second" finds although they really do not answer the questions I have.
Maybe I should be more specific?
Old 01-19-2007, 03:08 PM   #4
legacy05gt's Avatar
Bingo!
EN15000
120GB 2.5" SATA HD
1GB DDR2 Ram
M2-ATX PS
Slot-Load DVD
DWW-700M
Old 01-19-2007, 03:50 PM   #5
sama's Avatar
sama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud of
send packets to the ibus. to do that, you need an ibus interface. If I remember correctly, you need to send specific packets, as per Darth's thread, to get the thing going up and down, and switching video etc.
look for resler ibus interface, and I'd get the serial verison if I were you, not the USB (for hibernation issues).
hope that helps
///Mputer - Velocity - TomTom - Vision - Bezel - CarPC
sama is offline   Reply With Quote
Old 01-19-2007, 03:55 PM   #6
Well, lets give specifics a shot then. I got this far from DarthTater:
Quote:
I'm actually not interfacing with the car's ibus, but instead, simulating the ibus enough to operate the screen. All it takes is a pull-up resistor (10K) to twelve volts. I finished the screen wiring this afternoon - used a single Cat 6 cable to run both the video and the "simulated" ibus from the PC in the trunk. The LCD itself is a 6.5" but it requires RGsB at NTSC or PAL timings. I use an old Matrox G200 and Powerstrip to generate the right signal. Mostly since the G200 will also output the required Sync on Green natively. As for data packets there are only a few relevant ones. First, the monitor needs 80 xx bf 11 01 xx - which is a general bus-wide wakeup (key on). Then you can use 3b xx f0 4f 11 11 xx and 3b xx f0 4f 01 01 xx to turn the video on and off respectively. The monitor also needs a keep alive packet sent every 18-20 seconds - 3b xx 46 01 xx. I send it every 10 or so just to be safe - the count resets everytime it receives the message. And finally, to turn the monitor off, send 80 xx bf 11 00 xx (key off). For those who arent' familiar the packets are structured like so:
aa bb cc yy yy yy yy yy xx
aa - sending device address
bb - total packet length
cc - receiving device address
yy - data
xx - checksum
So, where/how does the pull up resistor install and how does one "send packets"? Does someone have a schematic of the wiring hookups for one of these units? How does the VGA output end up a RGsB input? I can see compensating with Powerstrip but does that change the signal as well?
Are there any specifications on this screen? Is the resolution high enough to support video? Is there another screen that will fit in this case with minimum fuss? Does anyone have dimensions on one of these units?
Old 01-22-2007, 04:02 PM   #7
Anyone?
Old 01-23-2007, 01:28 PM   #8
Now I am really confused. I got some information about the iBus interface,
"The interface will allow you to talk and listen to all devices connected to the IBUS in your car with a PC and some software."
Ok... so do I need an iBus, a screen, and a interface to turn it on? This is not making any sence.
REG HACK: display what files are being read during windows load RoyN WinNT Based 2 04-26-2007 12:23 AM
Choosing a Character display... Kryten LCD/Display 3 10-16-2003 11:43 PM
