Old 03-02-2007, 09:13 AM   #1
tolassssss is an unknown quantity at this point
back light in the screen lilliput EBY701
the problem is , when i Power on the monitor, the led shows blue but the screen shows black, i dont have a a back light but i see osd, how resolve this problem???
tanks
please help me
tolassssss is offline   Reply With Quote
Old 03-02-2007, 05:30 PM   #2
_psych_'s Avatar
_psych_ is an unknown quantity at this point
so, your monitor is technically on, correct? if so, do you have your vga cable properly hooked up? is your pc on and running?
Du bist häßlich.
_psych_ is offline   Reply With Quote
Old 03-02-2007, 06:12 PM   #3
DIGItonium
Guest
Posts: n/a
Back light failure? Probably a loose connection along the lines of the CCFL tube and inverter. At worst, probably a failed inverter.
Old 03-02-2007, 07:40 PM   #4
Banned
Motorcity's Avatar
Motorcity is on a distinguished road
Or the backlight itself has failed, or is broken.
I have a new lcd panel and a new ccfl backlight available.
Motorcity is offline   Reply With Quote
Old 03-03-2007, 12:37 AM   #5
spacehcc is on a distinguished road
I think the problem is the VGA cable or the signal, because OSD is visible.
Try different Modes (different resolution, frequency...)
spacehcc is offline   Reply With Quote
Old 03-03-2007, 06:43 AM   #6
when i put computer runing the led comes tu blue , i dont see the window but i know the monitor recieve the input vga, because is in auto power on, when no signal vga the led shows violet, when input signal vga the led shows blue , but i dont have a back light ,
Old 03-03-2007, 01:55 PM   #7
bbalazs is an unknown quantity at this point
What you mean OSD? On-Screen-what?
When you can see anything on the display, you HAVE backlight.
You can check it very easily, just turn off the light of the room or go into a dark room with the door closed. Put your finger on the led. If you see the slightest light coming from the display, you have backlight (usually, a 'black' LCD screen with backlight on will give you a possibility even to read).
When the room remains pitch black, you have right and your BL is off.
bbalazs is offline   Reply With Quote
Old 03-03-2007, 03:20 PM   #8
I see in the center of lcd one rectangle with lethers very dark, ( maybe no signal) when i dont have anything plug in monitor and then the monitor goes off and the led shows violet.
When i plug comp. in the monitor, the led show blue , when i turn off the comp. the led shows violet
Old 03-03-2007, 04:38 PM   #9
OK. Try to present a picture with good contrast. e.g. bouncing box in dxdiag
or a white on black text with HUGE letters in Windows Paint.
Is anything (dark, but visible) on the screen? Even when you light it with a strong lamp?
Normally (when it WAS good before), what was the color of the led during displaying the picture? I suppose blue.
In this context, I think there is something with the backlight.
Open the case, check the backlight fuse. Then check the two main switching transistors (or FETs) next to the transformer. These are trivial and frequent errors. When it does not help, ask an expert or a serviceman.
Old 03-03-2007, 04:48 PM   #10
do you have any photo of this fets? where is the fuse of back light??? on pcb or lcd????
tanks???
Old 03-03-2007, 04:54 PM   #11
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
it is a backlight problem. The OSK he is trying to describe is the on screen menu when you push the menu button on the LCD. It gives you the configuration options for the screen. The blue/violet/red sequence is exactly what I have.
Normally the OSK is bright white. If it is not white, then there is a problem. Check the 2 thick wires, running to the inverter screen from the main board. The plug that holds them is really easy to fall out. So if you are looking at the screen from the back (LCD table down, Back case facing you) undo all the screws, and pry off the case. Then on your left will be 2 large ribbon cables, and a yellowish 4 pin see through wire. Unplug all of those, and then you can lift the left of the screen up, and hinge it on the right side. The part still holding the right screen down should be the inverter wires. If it is completely loose, then you have a problem.
Old 06-14-2007, 06:57 PM   #12
thebigman007 is an unknown quantity at this point
Same Issue!
Hey all!
I have the same problem. I press my power button and the screen remains blank. I looked at the LEDs to see if power was coming to the unit and it was (lights all turned blue). I then checked my monitor cables and connections and they all seemed fine. My screen has the auto-on (option is checked).
If I turn off my car, the screen will stay on because it is running off the cigarette lighter so if the I turn the car back on the screen would go blank. Now, the screen doesn't turn on at all! I checked the lights and they still come on but the power light also has a red light on with it.
Let me know if you guys have any ideas.
I am going to try using the wall plug and see if it is my ac adapter.
Thanks!
thebigman007 is offline   Reply With Quote
Chinese company will not send my screen back and its been 5 months !!! TheGuy General Hardware Discussion 25 04-06-2007 04:03 PM
FS: 7” lilliput touch screen. (model 629GL-70NP) dodgedak Classified Archive 7 07-28-2006 11:36 AM
Lilliput Screen Getting Too Hot? we87 LCD/Display 4 05-19-2006 04:57 AM
8" Lilliput question, extracting sound and screen rolls clean customs LCD/Display 5 06-30-2005 11:10 PM
Lilliput screen inside motorized unit? JayKaye LCD/Display 38 09-29-2004 02:14 PM
